Tr 224/112?
Old Dec 21, 2006 | 05:26 PM
cino's Avatar
Default Tr 224/112?
I'm about to buy a used TR 224 on 112 LSA. I got the pictures and there are
numbers cast on the cam as follows:
3715R/3715RHR112 and X5174
Can someone tell me if this is the real TR 224 with 112LSA?
Old Dec 21, 2006 | 06:53 PM
T-maxx's Avatar
I would just give TSP a call and order it from them or another supporting vendor. If it's going in your car paying another $40 might be worth it. More info would help, what's your plan?
Old Dec 21, 2006 | 06:54 PM
99blancoSS's Avatar
Call Thunder and ask them. TR224 is a Thunder Racing cam
Old Dec 21, 2006 | 07:28 PM
hammertime's Avatar
3715R/3715RHR112
3715 is the Comp XE 224 lobe with .568 lift according to my lobe sheet. The two lobes should be the same by that number scheme, and the 112 should be the LSA. Seems like it should be correct, but a cam card (from the seller) would have been nice.
X5174 may be Thunder's grind number - a call or PM might help confirm that and ensure you that it is what we're thinking it is.
Good Luck!
Old Dec 22, 2006 | 09:14 AM
cino's Avatar
Thanks guys. I will call Thunder Racing.
