switch cam with new heads
Old Dec 24, 2006 | 04:42 AM
john563's Avatar
Default switch cam with new heads
Im an A4 with aTR224/112 cam and i just bought TSp 5.3 stage 2.5 heads and was wondering if i should switch to a tsp 233/239 cam.How much hp would i be leaving on the table if i stay with the Tr224?Would I have to switch rear gears to use the 233/239 cam(currently 3:23 gear).If i did switch would it feel slower down low? How much HP is this cam worth over my set up
Old Dec 24, 2006 | 04:50 AM
PREDATOR-Z's Avatar
IMO, maximize your setup with increased compression and tighter quench. Keep your gears.
Old Dec 24, 2006 | 11:34 AM
The Sad's Avatar
Hey, I have close to the same question: https://ls1tech.com/forums/generation-iii-internal-engine/628987-keep-221-221-go-233-239-a.html
Some good reading in there I think.
Old Dec 24, 2006 | 12:01 PM
white_camaro's Avatar
i love my cam but i only hear good things and good power/tq numbers with the 224 and a good set of heads. the cam swap would not be worth it. as far as losing low end torque with a bigger cam, well thats what bigger stalls are for. my 233/239 doesnt too well down low but guess what, im hardly ever there because i have a 3800 converter. guys with m6's are usually the ones that need to worry more about low end. if anything though id listen to predator, hes the expert on here and he really knows his stuff.
Old Dec 24, 2006 | 12:59 PM
hammertime's Avatar
If you don't already have a stall, you'll definitely want one with the larger cam. Predator's suggestion is the best bet. Even 10.75:1 is not quite where you want to be with that cam. By my calcs, an 11.35:1 compression ratio should give you a DCR of 8.6:1, and really bring that cam to life. I figured using XE 224 lobes with 277* duration @ .006", an ICL of 112*, 62 cc chambers and .040" head gaskets.
Old Dec 24, 2006 | 04:13 PM
john563's Avatar
I think your right about keeping my cam and maximizing my set up,but how do i increase compression with these heads?Would milling do that(which i dont really want to do)?What about gasket thickness?,if yess what kindshould I use on these TSP5.3 stage2.5 heads and can I get theme from jegs/summit and what is the part number?I just want to make sure I get the right gasket
thanks
john
One more question.Would raising the compression still be okay to spray later
Old Dec 25, 2006 | 02:40 AM
PREDATOR-Z's Avatar
You can use a Mr Gasket .042 gasket, (good price, quench and product) that will shave a little over 2cc from your compression.
Stage 2.5s are ~63cc so you'll be closer to 60.x cc
In the neighbourhood of 11.4x :1
Old Dec 25, 2006 | 11:27 AM
john563's Avatar
does jegs or summit carry this and if so what is the part number or can i just call em up and they will know,do i need to specify for ls1 or what.I have a jegs a nnd summit gift cert. and plus im in Ohio and will get it next day.I dont want to be waiting for gaskets in the mail when i have vaction on the 8th of jan and can drop my car off if i got alll the parts .
thank you so much for you help
john
Old Dec 25, 2006 | 11:30 AM
PREDATOR-Z's Avatar
Summit carries it
Old Dec 25, 2006 | 11:51 AM
john563's Avatar
Summit carries it
is it.042 cuz all isee is a.040 part #mrg-3143g
Old Dec 25, 2006 | 12:03 PM
PREDATOR-Z's Avatar
MRG-5713G Mr. Gasket Ultra-Seal Head Gaskets
Head Gasket, Ultra Seal, 4.000 in. Bore, .042 in. Compressed Thickness, Chevy, LS1, Left Side, Each
Tomorrow $20.39
Old Dec 25, 2006 | 12:23 PM
john563's Avatar
Tomorrow $20.39
Thanks for going over and beyond to help me out I really apreciate it.I will give summit a call tomorrow.I just wanted to make as much as i can N/A with my set up.I will eventually do spray just for the track,but its mainly a street car so good N/A power is what i want that s why I dded cam,heads instead of just a big shot of spray
thanks again
john
Old Dec 25, 2006 | 12:59 PM
PREDATOR-Z's Avatar
Anytime, Merry X-Mas
Old Dec 25, 2006 | 09:03 PM
john563's Avatar
merry christmas to you and your family and have agreat new year
thanks again
john
Old Dec 26, 2006 | 12:10 AM
The Sad's Avatar
Predator-z, is 11.4x:1 Ok on pump gas? What is your opinion of those heads, that compression, and a 221/221 .558/.558 114 cam?
Thanks, Aaron.
Old Dec 26, 2006 | 02:36 AM
john563's Avatar
aaron
not to get off topic but we have very similar mods and it seems goal except i dont have n20 yet but i was wondering how is your rear 10 bolt holding with the mods you have and do yoou think it will hold with the h/c and the n20
Old Dec 26, 2006 | 02:44 AM
PREDATOR-Z's Avatar
With lower durations, you can go with less compression. 61.x cc (.010 mill), stock gasket or a .042 gasket and no mill.
Octane use is more relative to DCR than SCR, so you would be fine on 93 octane. With a tune of course.
Just something I hope everyone understands is the 5.3 L heads are great with low duration cams, but if you're gonna go bigger later, then I recommend the PRC stage 1 with duals as an option.This way you leave ur options open for later.
Old Dec 26, 2006 | 09:12 AM
The Sad's Avatar
Why is that? Is it for valve clearance?
Originally Posted by john563
aaron
I'll send you a PM
Old Dec 26, 2006 | 12:13 PM
PREDATOR-Z's Avatar
Yeap, PTV
Old Jan 2, 2007 | 12:30 PM
JimMueller's Avatar
I'm considering the PRC 5.3's... what range of duration do you consider acceptable for the 5.3's?
