382 all bore engine/solid roller
my 1970 camaro .
Before I install the engine I was thinking
of tweaking it a bit .
Couple things I woud like to know :
Has anybody had any failures with the 382 all bore. Like splitting a cylinder sleeve ?
I'm not used to seeing a sleeved block ,I would
like to know what the wall thickness is of the sleeve. Things look pretty weak to me.
I would also like to run a solid roller .
Are the cam companies building stuff for
the LS1 yet or is it all custom made stuff?
I see that shaft rockers are available .
Just wanna know before I go dump serious $$
if its gonna be a problem.
Thanks.
[ February 03, 2002: Message edited by: A70camaro ]</p>
set up .
For a Jesel shaft rocker system ,
part #K2A-3012203 $$1416.00
for JEsel solid lifters $140.00 each X 16 $2240.00
using stock locator plates
and a custom solid roller cam $450-ish
lets see.....$$4100.00 , i'm laughing :-)
there has to be a better way .
How bout gutting the hydralic lifter bodies and inserting a tool steel slug ?? it would work.
use the TD shafts or compcam rockers
that would be about $1200 total with the cam
Also I believe the crane solid's for LS1's go for 350-500.
But don't forget to add in machine work for appropriate springs, and valve cover spacers, etc.
Chris
[QB]I just picked up a LS1 to install into
my 1970 camaro .
ask nineball he has lots of axperience w/382 all bore. His seemed to hold up OK before he sold it. Personally I wouldn't hesitate for a minute. I looked into having
MTI do my C5 but it was going to cost close to 2x that of an ATI SC. just don't have enough $$ for the 382 mods. end up w/ SC
[ February 04, 2002: Message edited by: bofrcNoir ]</p>
