cam guru's in here please...(Pat and predator Z)
Huh? Where did I say where the setup peaked? I didn't that I recall.
But the point was it was just a thing of amazement. The bottom end was built, and the car kept pulling pretty well, so he said screw it, let's see where it pulls to, since it shouldn't have been pulling that far, in theory.
Do you live the LS1tech theory only, bro? It was just having some fun since it wasn't supposed to do that. That car was a beast. Ran really good. Just that stupid gay 114 LSA wanted to keep pulling.
I'll be glad to take this opportunity to learn from ya, Predator-Z. Help me understand how you know where a cam peaked without knowing about the intake, heads, and exhaust. I'm pretty new to these cars and only repeat what I see happen. I don't know as much as you, and I always thought that a cam's peak was determined by all these factors as well. Which explains why in my dyno graph in my sig my old 224 was just peaking at 6600 (when we let off because my PTV clearance was low when we set it up and couldn't raise the rev limiter as high as needed). My heads were, from the way the cam wanted to act big and for lack of a better term, "too much head" (with too little compression) for the little cam. At least that's the conclusion that me and the builder/tuner came to.
Thanks in advance for any help, and Merry Christmas!
LS1 Tech Administrator
The reason why Predator Z can make the statements he does is only because he's either owned, tested or seen literally hundreds of cam combinations with LS1s over the years. Once you've seen over a dozen G5X-3 cam dynos (either on 112LSA or 114LSA), you begin to form opinions about them from experience. You get to know at which rpm they peak and what kind of power they make. When running an LS6 or FAST intake, they will make peak power in the 6300-6500 rpm range.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic210_1.gif)
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
What about a 226/230, XE-R lobes on a 108+0 LSA? Wanting to shift under 6300 RPM with a 6-speed. I had considered a 110+0 LSA, but maybe a 108 would work better.
So basically, just have it ground 1* advanced? I figured I wouldn't need to running that short of a duration cam.
Personally, I'd grind it straight up and put in an adjustable chain during the install. That way you have the freedom later to advance 2* if you want more power down low or retard 2* if you decide it peaked too early. 2* won't make a huge change but can fine tune your power curve enough if straight-up isn't good enough or your goals change a bit.
Originally Posted by Ragtop 99
For a 6200 shift, you can go with a 107 ICL and have a tiny bit more power down low.
Originally Posted by SVThis
hey guys...im bout to start a cam swap on my car but as u all know its a hard to decide with all the cams out there (expectially when u dont know much about cams)
welp, to help you pick the cam for me here is what id like to have...
I want a LOUD, HARD LOPEY cam that will sound really agressive on crusie ins and such. My car is NOT a DD in fact it only gets drove on warm, sunny, summer weekends, so high lifts and long durations dont scare me...also its an automatic and i dont wanna STALL the crap out of my car (thats what makes my decition so hard or id just throw in the T-REX)...also i want it to be a street beast cause i dont go to the track much, yet i do some. this is will be a cam only application for a good while as well considering im a college student will small money funds...
thanx in advance and if u have any more questions, ask and ill answer
You want a big cammed small stalled street beast. LOL
You guys are waisting your time giving him advice, look at the cam he's proposing. Just another parking lot poser.
Originally Posted by OhIt'sBeenBraughten
You're in college and spell like that? Spend 10 of those dollars on a dictionary...
You guys are waisting your time...
I always have that happen. I jump in to smart off about someone's spelling, and I misspell something while doing it. Ask Earl. It's karma.
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
#33
Originally Posted by PREDATOR-Z
And if you want to advance/retard odd degrees, then as you said, grind 1* in and do the rest via t-chain.
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
There's enough slop in cam grinding, that they can be off a degree or so, the even grind may end up with an odd ICL. I suggest 2* increments because that's probably enough to register on an assdynometer. I haven't used it, but comp makes one that is infintely adjustable. I have the reliable 2* increments.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#34
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
thanx for caring though...
and yes i already stated that i dont know anything about cams...i know what the "PROVEN" BIG, Med., and Small cams are and honestly i really dont want anyo of those...i wanna sound good/perform great on the steet...but i dont wanna be showed up at the track...i think what info these guys have gave me is more than enough but u my friend, are a dick
#35
Super Hulk Smash
Spinning over 500 rpm beyond peak is pointless, that is an indication of undercamming for setup or a choke in the intake area.
#36
Oh and you can't have it all on a cam. Gotta choose. You can't have a track beast and a tame driver. It doesn't work that way. So YOU should decide what you like if you're gonna want a combination of performance factors.
#39
#40
