ASA cam base circle vs stock??
I am trying to see if I can reuse my hardened 7.4" pushrods with the ASA cam if I get my heads milled .020" and use a .040" head gasket.
0.525/0.525" verified installed @ 0.308/9" actual lift
110 degrees LSA verified installed
What I measured;
Base circle 0.760"
Intake lobe centerline 108 degrees
Exhaust lobe centerline 248 degrees
Duration at 0.006", I=282, E=292
Ramp rate = 56
