help with a 93 lt1
Old Feb 3, 2002 | 02:13 PM
Damian's Avatar
LSX Mechanic
Default Re: help with a 93 lt1
Arking wire maybe? Who ran the plugs wires?
Try www.camaroZ28.com in their "LT1 Tech" section. There is a LOT more LT1 info over there. Good luck
Josh
Old Feb 3, 2002 | 09:19 PM
fws98ws6tt's Avatar
thanks ! the apple core gear was replaced.the timeing well i was told ( not my car)would not or could not jump yea i know.this man runs low 6's in the 1/8 in his race cars. but the main problem is he's old cars not high tec!!! new ones.the smoke out the tail is not black but blue . michael
Old Feb 3, 2002 | 09:25 PM
1320's Avatar
Some of your information must be wrong.....93's don t even have a crank sensor so how was it changed three times?
The 93 opti is different from later versions and so is the coil and module......
They can be retrofitted with newer parts but the wiring needs to hacked......so that could be an issue if it was done.....I dealt with one that had a similar problem for that reason.....the gm techs messed it up....
Old Feb 3, 2002 | 10:34 PM
fws98ws6tt's Avatar
i've never had to deal with a lt1, yep i'm old at heart - 327,350, 427 ,396, etc.the lt1 is strange to me , it's bad when i went 91&92's 305 motors to ls1's.i must be brain dead missing the 93-97 motors.michael <img src="gr_emb.gif" border="0">
Old Feb 4, 2002 | 12:04 AM
fws98ws6tt's Avatar
Default help with a 93 lt1
this is what it's doing,very hard to crank, if it does run its bam pop crack,you have to pat the gas to the floor then off to keep it running.will not idel has 3 new crank triggers ,1new coil, new fuel pump wires etc sets a code 41 but had a new distribter put in . sounds like it jumped time, the car was running fine, parked over night then it started all of this. and no it was not drove in water, is it 1/2 of the brain gone bad? help michael
Old Feb 4, 2002 | 12:47 AM
don's Avatar
don
are you sure the rotor didn't burn through?common for opti-spark.also,did the distributer gear apple core?sounds like it's out of time.
