Opinions on next mod...
PA Racing Chromoly K member
or
JPR Electric Water Pump
<img src="graemlins/gr_cheers.gif" border="0" alt="[cheers]" /> Justin
[ February 05, 2002: Message edited by: Jsears8 ]</p>
<img src="gr_tounge.gif" border="0"> <img src="gr_grin.gif" border="0">
Seriously though, If the pump is good for the numbers advertised it looks like a worthwhile mod. I would think they would be very close. Like BIGBOS said how much weight savings for the K member?
I think that the water pump would be a good shot b/c I am not too sure if I would want to disassemly my suspension for just a few pounds even though it would look very nice
Josh Sullivan <img src="graemlins/gr_chug.gif" border="0" alt="[chug]" />
Josh
The chromoly K-member is 25.5#s lighter then the stock one, and A-arms are abut another 12lbs.
Justin
If you do plan on the k-memeber, I would do the mild steel. The chromemoly is only 1-2lb lighter than the mild steel and the mild steel would be better on the street. It is also cheaper.
Taking 44 pounds off the nose will help. A lot.
It is a proven mod that works. It also will help keep you from breaking other parts and will/should improve your 60's.
Good luck.
