Do we have any ELECTRICAL experts among us?
Old Feb 7, 2002 | 01:39 AM
Damian's Avatar
LSX Mechanic
Default Do we have any ELECTRICAL experts among us?
If so, I've got a good one for ya. I am horrible with electrical stuff.....
I was fixing a broken needle in my buddy's 99 T/A cluster, and decided to see how his cluster would look in my car, since my cluster was out as well. When I plugged in the T/A cluster, the only thing that lit up was the left turn signal marker, and immediately I heard a slight sizzling sound and then POP. When I looked under the hood, I couldn't see any visual damage, but some white smoke was in the air and it smelled like burnt plastic. I hunted the smell, and it's coming from the RIGHT side of the engine bay.
Then, I go to pop the Camaro cluster back in the car. When I turn the key to the on position, I still get the sizzling sound like something is about to pop again. I do not want to leave the key in there long enough to get out and look.
Any ideas? Electrical problems are a PITA to hunt down and fix. <img src="gr_images/icons/mad.gif" border="0">
Old Feb 7, 2002 | 01:41 AM
Colonel's Avatar
Default Re: Do we have any ELECTRICAL experts among us?
Uhhh...NOPE!
Old Feb 7, 2002 | 08:09 AM
Scalpel's Avatar
Damn, that doesn't sound good. Anytime smoke and that horrible burnt plastic smell comes into play something is typically ruined <img src="gr_sad.gif" border="0"> <img src="gr_sad.gif" border="0">
Old Feb 7, 2002 | 08:52 AM
Nine Ball's Avatar
LS1Tech Co-Founder
My old electronic circuits professor used to joke about "letting the smoke out" of circuits. "Don't ever let the smoke out" he used to say.
I think you just did. $$$$$$
Tony
Old Feb 7, 2002 | 09:03 AM
Slowhawk's Avatar
LS1Tech Sponsor
I'll say this"don't plug it in again"
Sounds like your plugging your buddies gauges into your car.They are not wires the same!!!
If it is right side,as in pass side.BYE,BYE computer.The gauges get there signal directly from the computer,so if the gauges are wired wrong and shorted it can cook parts in the computer IE:sizzling.
Does the car still run?
Old Feb 7, 2002 | 09:17 AM
Damian's Avatar
LSX Mechanic
[quote]Originally posted by Slowhawk:
<strong>I'll say this"don't plug it in again"
Does the car still run?</strong><hr></blockquote>
Well I don't plan on trying to put them back in again LOL. I really didn't think that the wiring would be different, and especially not something that would cause a big electrical problem.
Does the car still run? I dunno, turning the key to the on position and hearing the sizzling sound is an indication that I should turn the key back OFF. At first I thought it was the computer, but the smells seems to be coming from the front of the car.
Old Feb 7, 2002 | 09:39 AM
Chris99WS6PWTMET's Avatar
Well the front of the car is where alot of your fuses and relays are mounted. Have you checked all of those yet? If not that would be a good place to start. Good Luck to you.
Old Feb 7, 2002 | 11:35 AM
Damian's Avatar
LSX Mechanic
Checked all the fuses, none of those <img src="gr_sad.gif" border="0"> .
I think the computer is fried. Lucky for me I have a 98 which is the most expensive and hardest to find. Lucky me.....
[ February 07, 2002: Message edited by: Damian ]</p>
Old Feb 7, 2002 | 11:38 AM
Scalpel's Avatar
I concur, most likely PCM <img src="gr_sad.gif" border="0"> . Good thing you have a spare one.
Old Feb 7, 2002 | 11:50 AM
Damian's Avatar
LSX Mechanic
[quote]Originally posted by NastyC5:
<strong>I concur, most likely PCM <img src="gr_sad.gif" border="0"> . Good thing you have a spare one.</strong><hr></blockquote>
NastyC5, I was referring to the year of my car. Not that I had a spare <img src="gr_sad.gif" border="0"> .
Old Feb 7, 2002 | 11:54 AM
2000 Camaro SS's Avatar
I don't think he has a spare I think it was a little depressed sarcasm. <img src="gr_sad.gif" border="0">
Old Feb 7, 2002 | 06:29 PM
99WhiteSS's Avatar
Shaun (valvegod on LS1.com) sells PCMs for $140...I guarantee you WILL NOT find it cheaper ANYWHERE....check him out: (248) 276-0483
-Kris
Old Feb 7, 2002 | 07:48 PM
Scalpel's Avatar
[quote]Originally posted by Damian:
<strong>
NastyC5, I was referring to the year of my car. Not that I had a spare <img src="gr_sad.gif" border="0"> .</strong><hr></blockquote>
I read it wrong, sorry man <img src="gr_sad.gif" border="0">
Old Feb 8, 2002 | 12:11 AM
kewlbrz's Avatar
[quote]Originally posted by Nine Ball:
<strong>My old electronic circuits professor used to joke about "letting the smoke out" of circuits. "Don't ever let the smoke out" he used to say.
Tony</strong><hr></blockquote>
Hehe, mine too. Electronics need their smoke to work. <img src="gr_stretch.gif" border="0">
Old Feb 8, 2002 | 05:06 AM
Damian's Avatar
LSX Mechanic
[quote]Originally posted by 99WhiteSS:
<strong>Shaun (valvegod on LS1.com) sells PCMs for $140...I guarantee you WILL NOT find it cheaper ANYWHERE....check him out: (248) 276-0483
-Kris</strong><hr></blockquote>
Kris, thanks. I talked to Sean, he has one 98 PCM. Even with a 1/2 off *** raping coupon the price is still 250 bucks <img src="gr_images/icons/mad.gif" border="0">
