382 and fuel (injectors)
Old Feb 8, 2002 | 04:13 AM
RUF SS's Avatar
Default 382 and fuel (injectors)
I am installing a 382 with a 226.5 cam and all the bolt ons. Do I need bigger injectors?
Old Feb 8, 2002 | 08:30 AM
Nine Ball's Avatar
LS1Tech Co-Founder
Default Re: 382 and fuel (injectors)
Some people will say yes, but I'm still running on a completely stock fuel system and I actually have to lean my computer tuning out a bit.
Tony
Old Feb 8, 2002 | 09:40 AM
Mike TexaSS's Avatar
8 Sec Tuner
The answer is yes i think LS1 guys tend to stray away from injector swaps because the software was just no there for them to reprogram the PCM. But i went from 24lb SVO injectors in my stroker to 30lb svo's (and programed the PCM for them) Because i had hit the limit of my injectors. And 24lb SVO's out flow stock LS1 injectors at the LT1 43.5 fuel PSI. So i would definently swap in some 30lb SVO injectors with out a doubt!
Old Feb 9, 2002 | 12:58 AM
RUF SS's Avatar
Thanks! <img src="gr_grin.gif" border="0">
I will go bigger i guess. But i think I should dyno first.
Thanks again.
