Question?
Old Feb 9, 2002 | 08:19 PM
Orange Krush's Avatar
Default Question?
What kind of gains can I expect to see by bolting on a LS6 manifold to my 99 Z? Also do these units come with everything needed to bolt on or do I need anything else to make it work? <img src="images/icons/confused.gif" border="0">
Old Feb 9, 2002 | 08:26 PM
11 Bravo's Avatar
Default Re: Question?
I think most are seeing like 10 hp on a stock engine. You can get them with the proper emissions hook ups for '99's. If you plan to get a cam and/or heads it is a must do if you want to wring out all the power you can.
Old Feb 9, 2002 | 08:29 PM
Thanx for the info! <img src="gr_stretch.gif" border="0"> Now another question this new Holley manifold that was designed by Lingenfeter is the same thing in aluminum or am I missing something there? <img src="images/icons/confused.gif" border="0"> Can I expect the same gains as the LS6 manifold or more?
[ February 10, 2002: Message edited by: Orange Krush ]</p>
Old Feb 11, 2002 | 12:09 AM
TTT
Old Feb 11, 2002 | 03:25 PM
ttt
Old Feb 11, 2002 | 04:00 PM
AgaveCorvette's Avatar
[quote]Originally posted by Orange Krush:
<strong>Thanx for the info! <img src="gr_stretch.gif" border="0"> Now another question this new Holley manifold that was designed by Lingenfeter is the same thing in aluminum or am I missing something there? <img src="images/icons/confused.gif" border="0"> Can I expect the same gains as the LS6 manifold or more?
[ February 10, 2002: Message edited by: Orange Krush ]</strong><hr></blockquote>
The casting is molded after the LS6 manifold. The Holley manifold is meant to be ported.
Old Feb 11, 2002 | 04:04 PM
Ok so as a bolt on mod it would be the same gain as the LS6 piece,but if I ported it I could potentially pick up some more hps correct? <img src="images/icons/confused.gif" border="0">
Old Feb 11, 2002 | 04:06 PM
<strong>Ok so as a bolt on mod it would be the same gain as the LS6 piece,but if I ported it I could potentially pick up some more hps correct? <img src="images/icons/confused.gif" border="0"> </strong><hr></blockquote>
Exactly.
Old Feb 11, 2002 | 04:12 PM
Excellent! Thanx! So now the only other manifold left to consider are the Spyder manifolds from www.nitrouswarehouse.com <img src="gr_images/icons/wink.gif" border="0">
