coated bearings
Old Dec 29, 2006 | 01:17 PM
rons 00z's Avatar
Default coated bearings
anyone have experiance with coated bearing (rod and main) and tolerances? should it be tighter or what? i'm at the point now where it's time for me to measure and stuff just not sure how much tolerance i should run. thanks, ron
Old Dec 29, 2006 | 02:04 PM
Gauge's Avatar
11Second Club
I did some research on this, and if you're talking about the Tri-Armor bearings from Clevite, they claim the coating thickness is .0003", so it's nothing to worry about. The coating is supposed to last, and if it doesn't for some reason it won't significantly change your clearance. I haven't heard anything bad about them yet, but I really haven't heard much at all.
Old Dec 29, 2006 | 02:15 PM
rons 00z's Avatar
actually i'm talking about calico. i guess they actually grind the bearing down then add the coating so you can get within the gap you're looking for.
Old Dec 29, 2006 | 08:30 PM
Steve - Race Eng's Avatar
LS1TECH Sponsor
Default Coated bearings
Bearing clearance depends on the diameter of the crankshaft main and rod journals, the main bearing bore dimension in the block and the bore size in the con rods. Some manufacturers grind their cranks on the low end of the tolerance range and even under that size. So you need to be careful with sizing of bearings.
No one "grinds" bearings before coating that I am aware of. I use Calico bearings and have found that I usually need to get two sets of mains, one std. and one X (.001" oversize) to get the main bearing clearance correct with a stock sized crankshaft - not one of the smaller aftermarket cranks. That is with the block align honed to the low end of the main bearing bore size range for max. bearing crush.
Steve
Steve
__________________
Steve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
Old Jan 25, 2007 | 10:21 PM
rons 00z's Avatar
thanks steve.
