How much "Slop" in your timing chain?
Old Feb 11, 2002 | 02:40 PM
JohnR's Avatar
Default How much "Slop" in your timing chain?
I'm in the process of installing a new cam and when I removed my timing cover I was surprised to see that the timing chain has about .350 - .400 play side-to-side. Is this normal? Do I need a new chain?
I'm installing a Comp Cams 216/220 with 26918 springs. I guess this is why Comp Cams grinds in 4 degrees of advance in order to compensate for the retarded sloppy chain.
Thanks for your help,
John
Old Feb 11, 2002 | 02:50 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Default Re: How much "Slop" in your timing chain?
[quote]Originally posted by JohnR:
<strong>
I guess this is why Comp Cams grinds in 4 degrees of advance in order to compensate for the retarded sloppy chain.</strong><hr></blockquote>
Exactly.
Old Feb 11, 2002 | 06:55 PM
-Joseph-'s Avatar
LSxGuy widda 9sec Mustang
I've heard the GM also grinds 4 degrees of advance in for the same reason. Those chains are loose new, but thats the way GM had Cloyes make them...
Old Feb 11, 2002 | 10:36 PM
Tin Indian's Avatar
I wonder if the CompCams adjustable timing chain set will get as sloppy as the factory OEM chain set after a few miles?
