So with the TR-55 plugs, a .050 gap will make it idles rougher?
Or is that only with the tr 6's? I was just reading another post about this, I have mine gapped at .050 after my cam install, I have exhaust and basic intake stuff, would I benefit from tightening up the gap a bit? Thanks fella's
[ February 11, 2002: Message edited by: brendon ]</p>
Re: So with the TR-55 plugs, a .050 gap will make it idles rougher?
No, that's TR-6s that we were talking about. TR-55s are designed to be run at wider gaps. They come from NGK gapped at about .055. NGK says that you shouldn't change the gap of a plug more than .010 in either direction.
You should be fine where you are. <img src="gr_stretch.gif" border="0">
Hehe, I sure do remember the heated spark plug gap debates! I believe you and I got into it a few times Tony! <img src="gr_stretch.gif" border="0">
I remember that a few guys were seeing a large dip on the dyno curve with the lower gaps, but it turned out that was a fuel related issue in the end wasn't it?
Personally if I were to do it again, I'd go with TR55s at .050. Back then I ran TR6s at .044 and they worked well for me though.
I bet my following questions have been posted a least a million times but here goes...I'm about to do a plug/wire swap, what plugs and gap for a bolt-on motor? Also, i've been checking prices of wires: stock replacements are about $10 a piece and the G.M.P.P. wire set (8 wires) is $50, wtf? Are the GMPP's any good? Are the stock ones any better? Also, any other wires you can recommend? Thank you very much for your time!
Chris
Chris
