Building a strong motor...please help!
ok besides getting a iron block or a stroker kit is there a way to build up my motor to beable to take lots of power (Nitrous) without spining a bearing or messing up thr crank? i just spun a rod bearing and this is my second time. This time i wanna make the motor strong so i won't have to worry about this problem. Please give me some pointers on what to do.
Re: Building a strong motor...please help!
sure...
your better off getting with are or some shop like that if you dont know where to start and talk to them.
get the crank cryo'd and indexed ect..setup for a good bearing maybe go with some of the new fancy coating's out ther on the market from polydyne or swain.
get it put together by some one that knows what there doing and it will live.
P.S.: dont skimp out on parts due to there price.
steve frank
steve frank
I assume that you will be including all of the other nitrous safety features:
Window switch
Filters
Upgraded injectors
Use a wet kit
A/F cutoff switch
But the above are not really motor mods, they are just how you apply the nitrous.
Window switch
Filters
Upgraded injectors
Use a wet kit
A/F cutoff switch
