220 duration requires computer programming
Old Dec 31, 2006 | 09:41 AM
TX01Z's Avatar
Default 220 duration requires computer programming
For A4 cars, Comp cams says their 216/220 duration cam requires computer modifications, however their 212/218 duration cam does not.
What needs computer tuning because of the higher duration? Idle rpm only, or other things as well?
Thanks.
Old Dec 31, 2006 | 09:56 AM
Grimes's Avatar
the things you mentioned and also to get the most power out of the cam. But the 216/220 is small enough that you could get away without it. Do you have an aftermarket converter for your car? At least have one put in before a cam swap.
Old Dec 31, 2006 | 10:12 AM
TX01Z's Avatar
SS3200. Was Comp cams referring mainly to the idle rpm?
Old Dec 31, 2006 | 10:24 AM
ArcticZ28's Avatar
Regardless of any aftermarket cam you put in, you will need to tune it. Granted, you will have to make less/smaller changes with a smaller cam, you still need to make them. The computer is programmed to know only about the stock cam, nothing else.
Old Dec 31, 2006 | 10:56 AM
WhosNXT's Avatar
Agree
Old Dec 31, 2006 | 12:25 PM
PREDATOR-Z's Avatar
Even the stock cam can use better tuning. On my vette, I gained 12rwhp by tuning the stock one.
Old Dec 31, 2006 | 12:31 PM
2xLS1's Avatar
Thanks.
I actually had both of those cams on 114 LSAs in A4 cars many years ago. The 216/220 would set enough misfires to keep the converter from locking while the 212/218 did not.
Old Jan 5, 2007 | 06:38 PM
TX01Z's Avatar
How do you tune out the misfires?
Old Jan 5, 2007 | 08:10 PM
2xLS1's Avatar
Edit the misfire tables with tuning software.
Old Jan 8, 2007 | 03:25 PM
KEE AUDIO's Avatar
My thunder racing 220/220 .551 .551 on a 114 needed tuning. Not much bigger than the one your describing? It would send a random multiple misfire code for no apparent reason from time to time and would stall at traffic lights if it sat still long enough. You would've thought it was a much bigger cam the way it behaved. All that with a Pro Torque 2800 stall. Much nicer after I had it tuned.
