Mikronited Valve Springs?? Benifits?
Well looking over the LSXtv i noticed CRANE CAMS is going to offer Mikroniting on almost all their products(Makes sense since they were acquired by them...
). So this begs the question, with all this talk about 25% more life out of anything Mikronited, would this beneficial to the valve train? Wouldn't Mikroniting a spring change it's characteristic's?
EDIT: Replaced COMP CAMS with CRANE CAMS cause i'm a dumba$$... =P
). So this begs the question, with all this talk about 25% more life out of anything Mikronited, would this beneficial to the valve train? Wouldn't Mikroniting a spring change it's characteristic's? EDIT: Replaced COMP CAMS with CRANE CAMS cause i'm a dumba$$... =P
crane cams was bought by mikronite, not comp cams.
http://www.vincihighperformance.com/...IN%20PAGE.HTML
again, it's about removing ridges and smoothing out the material. in doing this, it helps to strengthen the material as well.
Originally Posted by vettenuts
Are you sure they offer this on valve springs?
yep
I am not familiar with the process, but the residual compressive stress on the surface is the key for the valve springs. This is why PSI nitrides their springs, it too provides the residual compressive surface stresses. What is key is when you install them not to use a tool that physically grabs the springs, you need a tool that pushes on the retainer. Any scratches will negate the surface treatment.
