Fuel pump, please help!!
if my memory serves me right, there is no fuel cut off switch on our cars. also, if youve run it out of fuel, and it sounds like you did, then you more than likley have killed the pump. it needs the fuel to keep cool. no fuel and the windings in the motor will melt....
sorry
just to check tho, open the hood and remove the cap from the drivers side fuel rail end. it will be close to the throttle body.
there will be a small valve on the end of the rail after the removal of the plastic cap, push in on that little brass rod thingy bud and you should have fuel shoot out at about 60 psi or so. be carefull cuz it should go every where.
steve frank
