FLP Ring Clamps
Old Feb 15, 2002 | 08:33 AM
WS6Modder's Avatar
Default FLP Ring Clamps
Has anyone had these things fail on them?
Yesterday I heard a 'tinging' sound and looked underneath and could see the bolt of my rear driver side ring clamp was really loose. No problem I thought Ill just cinch her up when I get home. Well I get under the car, and go to tighten the bolt, and the damn thing falls out of the ring clamp! Then I notice the bolt is bent at a 30 degree angle! And the butterfly on the ring clamp is all whored out....then I notice that my front passenger side ring clamp is going to do the same thing soon as it is starting to bulge out.
I bought these in October. Do you think FLP will send me two new ring clamps? Anyone had this problem? Im thinking that maybe I cinched them up too tight, but I dont think so. Theyve been on the car for at least 3 months since I last swapped the cats and OR pipes with no problem.
Anyway...any insight/experiences welcome.
Old Feb 15, 2002 | 08:54 AM
Nine Ball's Avatar
LS1Tech Co-Founder
Default Re: FLP Ring Clamps
You had them tightened too much. If you overtighten them, the part that holds the "T" of the bolt will start to bend out. I carefully tighten mine until I see that section try to bend.
You can get replacement V-band clamps at FLP. The front ones are 3" and the rear ones are 2.5"
Tony
Old Feb 15, 2002 | 08:57 AM
Trevor @ Texas Speed & Perf.'s Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
I'd recommend e-mailing Dan @ FLP. He deals with the exhaust systems. dolarbills@sprynet.com I agree with Tony that they were overtightened.
__________________
Old Feb 15, 2002 | 08:59 AM
WS6Modder's Avatar
Dayum!
I suppose that had to be the case....
Thanks guys.
Old Feb 15, 2002 | 08:42 PM
Glenn98ZM6's Avatar
i saw that this was gonna be a problem when installing mine. so i took my clamps down to a local welding/fab shop and had them weld (TIG'ed) on some small strips of metal (stainless) to keep the loops from splitting apart. works perfect and i was only charged $20 for it. just dont go too close to the end to give the bolt some room to swing. now i'm worried about those cheesy aluminum nuts on there!
Old Feb 15, 2002 | 08:43 PM
Glenn98ZM6's Avatar
i also heard those clamps are FORD turbo diesel clamps for the turbo ducting.
