i think i have a collapsed lifter
Old Jan 1, 2007 | 03:04 PM
Boosted 99 TA's Avatar
Default i think i have a collapsed lifter
My engine is making a ticking noise and i had a misfire problem and i took the valve cover off and i had a bent pushrod...well i ordered my new one and it wont touch the rocker so i believe i could have a collapsed lifter, what do you guys thinkk? now to replace the lifters do i take the intake off or do i hav e to take the heads off too? that is kind of a dumb question but i think i saw somewhere that i had to take the heads off but i just want to make sure before i get into it this weekend. Thanks
Old Jan 1, 2007 | 03:10 PM
mxmccarter2401's Avatar
gotta pull the heads
Old Jan 1, 2007 | 03:37 PM
alright thanks man
Old Jan 1, 2007 | 04:29 PM
DaddySS's Avatar
Something sounds wrong, can you see the lifter through the hole? Is the valve spring at full height? How did you bend the pushrod?
Old Jan 1, 2007 | 05:03 PM
03 BUSA's Avatar
Same question here.
Old Jan 1, 2007 | 05:18 PM
i am not sure how it bent, its to hard for me to see the lifter through the hole, i was doin it at night with a flash light. What else could it be?
Old Jan 1, 2007 | 05:47 PM
DaddySS's Avatar
Basically, the pushrod bends because the piston hits the valve. In mild cases it's no big deal, but it rarely causes a lifter to collapse. If you had no tapping before this, check the spring height, the rocker etc. closely. If the lifter got turned and jammed, held the valve open etc. and that's what bent the pushrod, you may have several other issues to deal with.
Old Jan 1, 2007 | 06:20 PM
how do i check spring height?
Old Jan 1, 2007 | 06:31 PM
bfhawki's Avatar
You might as well go ahead and pull the head on the side with the bent pushrod. You are going to have to anyway even if the only problem is a collasped lifter. When you get in there, you will see if you have other issues.
Old Jan 1, 2007 | 08:07 PM
DaddySS's Avatar
Does the rocker look OK? The spring should bsically be the same height as the one next to it. Which cylinder and which valve are we talking about?
Old Jan 1, 2007 | 08:44 PM
the rocker looks fine...i will check out the springs tomorrow, im not in town right now but i will be in the morning. we are on cyl 4 and i believe it is the exhaust valve.
