MMS 229v2.1 cam only results
So here's the graph, track times in a week. Should be into the 11's on tire at 120+
We don't typically do the 229 as a cam only, but it was more a test to see how the stock heads respond. I think the compression is a little low for this cam. That really affects the low and mid range.
That cam with stock heads and a yank UT4800rpm stall would _really_ rock. I hope someone tries it out soon!
On both dynos.
First is a 01' that made 350 hp with a lid, and open borla, and a pulley.
Second is the 420 rwhp from a car with stock heads. Just a year ago, we couldnt figure out how to get above 400, and only 1 person had. Now a car shows 420. I feel like Im missing something...
Congrads! , but something just seems weird. I wish my ARE stage 3 heads/hammer cam/4.10s car made that much.
\chris
Damn, I think my little 226/226 plans just changed to a 229. Congrats on the results.
Do you wanna divulge anymore info. about that cam? What lope sep. etc. And will it work with .040 cut off the heads? Maybe if I sink the exaust valves a little?
Nice job Mike. I'de like to see a redyno w/3.42 gears. <img src="gr_stretch.gif" border="0">
Either everything MMS ever does puts out crazy numbers, or their dyno is screwed.
<hr></blockquote>
It's funny how a few MMS heads/cam cars were putting out 430-440rwhp a long time ago and everyone gave them ****. Now other vendors jump in quoting similar figures, and instead of being skeptical everyone asks them for a GP. (cough Cartech, LG, cough) <img src="gr_images/icons/wink.gif" border="0"> <img src="gr_images/icons/wink.gif" border="0">
My heads/cam A4 car did 395rwhp on the same dyno, same day (405 locked up).
no this is a pretty special car. It was pretty impressive w/out the cam and headers. Hell when he was basically stock he was running stronger than most of the mild bolt on F-bod's at LACR.
I knew this car would be a good candidate for a cam only swap. I didn't know it would pick up over 70 RWHP from a cam and headers. Probably lost a few because of the gears too.
I'm really trying to convince him to do heads soon. Should be another 30-40RWHP.
side note: I'm doing some testing on SAE corrections and how weather conditions.
my theory is that even though #'s are corrected a car will still produce better corrected numbers when the conditions are better.
I just dyno'd one car with no changes except for weather and it was down some power. I'm doing another car to compare. Should be interesting.
Terry, I find it funny you ride MMS's ******* so much. I understand you are happy with them, I understand they are a good shop, but jeez, lay off sometimes....you'll start to sound like JS and cartek. As for the car's numbers, I dont beleive it had much to do with the cam specs....more just the car's mojo itself (whatever that may be). A huge cam never gave me more than others and I dont expect this car is any different....I'm sure a T1 or a TR224 woulda been within a few hp of it.
I'm just hessitant to beleive some dyno #'s until I see it on a dyno I know and trust, right after another car dyno's realistic numbers. I'm sure yall understand that. <img src="graemlins/gr_cheers.gif" border="0" alt="[cheers]" />
Why don't you try out our 229 cam <img src="gr_stretch.gif" border="0">
I don't know about the car, but I do know we picked up over 70RWHP with cam and headers.
That may make you a believer!! <img src="graemlins/fluffy.gif" border="0" alt="[Fluffy]" />
Aren't you the official LS1 cam tester!!
Terry, get off Mike's *****. Your car isn't at all impressive. I guess you're the only slow one <img src="gr_tounge.gif" border="0">
There have been cars with the T1 to dyno over 400 rwhp. Add 8 degrees of duration, some lift, faster ramps, it all makes a difference, IMO. Almost everyone I've seen makes more power, at a higher rpm, with a bigger cam if the rest of the setup matches it. Maybe instead of this one car being a ringer, you just got a dud. Maybe both, maybe this is the high end of the tolerences and you got the low end.
An LG cam dynos ~390 thru an unlocked converter but no one can believe this cam in a manual dynos 420?
J.
<strong>Man that car is a SLUG under 4500rpm!</strong><hr></blockquote>
So what does your RPM drop to when you shift??
With 4.10's and some traction do you really think it would matter, or how bout a car running a 4400+stall, or how bout a car that is only on street radials, that already has problems hooking.
Like I said with stock compression/heads it gives up quite a bit down low. Plus he is running through a 2 1/2" Ypipe. A 3" Y would pick up the torque from 3000-4500 RPM.
I just wanna know whats special about that car. Try its stock heads on another car that dyno's normal numbers, or maybe try its PCM on another car. Maybe its the shortblock? I dunno....but I'd love to finally hear why some cars are beasts and some are duds.
Jon
"official LS1 cam tester" <img src="gr_grin.gif" border="0">
<strong>
J.</strong><hr></blockquote>
Yes, and every local car must be a dud too. I wanna see LG cars dyno at MTI or here in austin, just like I wanna see some MMS cars dyno here or at austin.
Just like people can get some great times at HRP, maybe some shops have the HRP of dyno's.
I'm not participating in this thread to stir trouble, I'm participating (and questioning the info) to see just WHY some cars are like this, and I'm not convinced its that magic camshaft. If it was just the cam, everybody all over the country would have 420 at the wheels now. If its something else, I'd like to know....certainly no other non standard parts on that car.
When people write off awesome numbers to a "combo" just clicking, I think thats a cop out. What combo is there? There are so few variables right now...everybody is using a 2001+ intake, his heads are the same we all have, and a long tube is a long tube for the most part...plenty of others have TTS's without making crazy numbers like that. So whats that leave to make the magic "combo"? The cam or the tuning...and I dont think its the cam.
And if you read graph, cammed setup actually beat non cammed torque from 3000 rpm up, not 4500! <img src="gr_images/icons/wink.gif" border="0">
<strong>Yeah, those #'s are definately very hard to swallow....What is so "special" about this car that it is making more than 90% of all other Heads/cam LS1's? No flames towards you Mike, but thats a LOT of power and to believe it came out of a stock headed motor.
I agree, that's why I show the before #'s. The car was strong before the cam and headers too.
It's not about the numbers, but more about the change.
If the car dyno'd 335 before(pretty common) and dyno'd 410 afterwards I'd be just as happy because of the total gain.
Even if the dyno is an optimistic one, it still showed a 70 rwhp gain.
J.
