Need Help with Power Steering Pump!
Old Feb 17, 2002 | 01:43 PM
99ragtopSS's Avatar
Default Need Help with Power Steering Pump!
We are in the process of removing the heads and installing new heads on my 99 SS, what is the proceedure for removal of the power steering pump? We have it stripped down and that is the last thing holding us up.
Thanks Guys
Old Feb 17, 2002 | 02:22 PM
jmX's Avatar
jmX
Default Re: Need Help with Power Steering Pump!
Look at my site in the sig. It details how to get it off the head.
The basic instructions are, leave all the lines connected, leave the stuff all on the bracket, and just remove the 3 bracket bolts from the drivers side head. You'll need a 15mm open ended wrench, and you need to work all the bolts out at the same time (do each one a few turns out, pull the whole thing off some, and repeat)
Old Feb 17, 2002 | 02:29 PM
99ragtopSS's Avatar
Your a good man jmX, I really appreciate the help. THANK YOU
Old Feb 17, 2002 | 05:46 PM
jmX's Avatar
jmX
No prob man, I just removed mine yesterday so it was all fresh on my mind.
Lemme know if you had any problems so I can update any instructions I may have typed up before.
Old Feb 18, 2002 | 05:46 AM
99ragtopSS's Avatar
Its off, the engine is down to the block, heads, intake, exhaust are all off. I am the proud owner of a $25,000 paper weight. <img src="gr_grin.gif" border="0">
Old Feb 19, 2002 | 12:25 AM
jmX's Avatar
jmX
Hrm, sounds about like mine right now
http://jmx.car-audio.net/car/apart.jpg
<img src="graemlins/gr_cry.gif" border="0" alt="[whiner]" />
