Cam
Old Jan 2, 2007 | 05:12 PM
black1999z28's Avatar
Default Cam
Want to rebuild my stock motor. I have read all the post about what pistons, rings and rods to get but need some help on what cam to get. Want to get a cam that is good for nitrous. Would like to spray around a 250-300 shot. Any input on anything this that I should look into when I do this build would be great. Would most likely to hear about diff cams to pick from. I was looking at the T-Rex but heard that it was not good for a big shot of nitrous.
Old Jan 2, 2007 | 05:37 PM
LS1Formulation's Avatar
Basically, you'd want a cam with about a ten degree split, but overall just spec it out to meet your power goals off nitrous. You need additional duration on the exhaust side to expel the much larger volume of exhaust that is present when you're on spray.
