How Many Bent Push Rods...
Old Feb 18, 2002 | 03:56 PM
99ragtopSS's Avatar
Default How Many Bent Push Rods...
Upon removing my heads in prepartation to install the ARE heads and cam I found 5 bent pushrods, 3 slightly bent, the fourth in a "bowlike" position and the fifth....we we will just say it resembles a "Z" better then a "I". <img src="gr_emb.gif" border="0"> <img src="gr_eek2.gif" border="0">
I was just wanting to hear abount someone elses woes. <img src="gr_stretch.gif" border="0">
Old Feb 18, 2002 | 04:42 PM
CKZ's Avatar
CKZ
Default Re: How Many Bent Push Rods...
Ouch! Thats pretty crazy...I would imagine you had some idea there was a problem though <img src="gr_grin.gif" border="0"> That many bent pushrods are bound to make your car run a little off <img src="gr_eek2.gif" border="0">
I think its a "go" on the shifter btw, what do the adjustable stops do anyhow? Do you have short shifter in your car now?
Old Feb 18, 2002 | 04:50 PM
AgaveCorvette's Avatar
I had a timing chain go on the original 305 in my turdgen. Broke EVERY push rod, and bent EVERY exhaust valve.
<img src="gr_sad.gif" border="0">
Old Feb 18, 2002 | 04:54 PM
2000 Camaro SS's Avatar
8 Bent push rods 1 bent intake valve. I beleive it happend about my 3rd or 4th run with N2O. Car still ran stong but I was off by 1 sec in the 1/4 after that. I did not know until I took it apart this winter do put in the cam and rebuilt heads.
Old Feb 19, 2002 | 05:56 AM
99ragtopSS's Avatar
TTT
Old Feb 19, 2002 | 08:24 AM
Matt98SS's Avatar
its happened to quite a few of us, I had one that was like a boomerrang
Old Feb 19, 2002 | 08:29 AM
Z O SICK's Avatar
I've had 2 bent pushrods and killed a rocker arm. <img src="graemlins/camaro.gif" border="0" alt="[Chevrolet]" />
Old Feb 19, 2002 | 08:49 AM
ExtremeZ28's Avatar
i broke one clean in half! and it was bent on either end to boot! <img src="gr_grin.gif" border="0"> i'll post a picture of it later tonight..
Old Feb 19, 2002 | 10:28 AM
TA_2001's Avatar
wobbled three during a mis-shift car had 4200.
Old Feb 19, 2002 | 11:30 AM
thxone's Avatar
99ragtopSS, isn't there alot of valve tapping after bent push rods? I heard your car at OSW and it sounded quite. I concerned, I have hit the rev-limiter several times and I now wonder if I too have bent a few.
Old Feb 20, 2002 | 12:40 AM
Bluestreak's Avatar
[quote]Originally posted by thxone:
<strong>isn't there alot of valve tapping after bent push rods? I heard your car at OSW and it sounded quite. I concerned, I have hit the rev-limiter several times and I now wonder if I too have bent a few.</strong><hr></blockquote>
I was the lucky soul pulling pushrods from 99RagtopSS's motor... we were all in awe of how many bent ones there were. He missed a shift on the track that night... it must be when he bent them.
My car had visited the track twice as of the cam install on 8/4/01. That day we pulled two bent PR's from my car - one that was sharply bent in the middle, and the other was slightly bowed. I am in no way, shape or form rough on my car since 98% of its 30,000-mile life has been light street duty, so chances are if you've revved that motor up high with any frequency at all you've probably bent a pushrod, almost certainly if you've ever had the motor rev up violently as a result of a missed shift, etc.
The good news is that it's a 60-minute job to change out all 16 PR's. Crack the valve covers and check those PR's. I only replaced the bent ones in my motor, they're $11.59 each.
