Car shudders under load
Old Jan 2, 2007 | 08:52 PM
Toasty's Avatar
Default Car shudders under load
In the last week of driving, my engine's been having issues. When trying to apply throttle under low RPM, the car shudders as though it is misfiring, but I have no thrown codes for that. I thought it may have just been bad gas, but I've completely filled the tank at three different gas stations with no effect. Just tonight, while at a higher RPM (about 80% throttle) I heard a clap noise from the exhuast and immediately let off the gas and babied it back home. Sounded like a backfire almost. I popped the hood to listen for noises, and there is a barely audible, intermittent tap noise I can hear through the normal sewing machine clutter. Its not nearly as loud or frequent as the "bad lifter?" thread though.
Any suggestions/ideas? I'm about to do a cam swap soon, so I'm hoping its nothing that will require me to take the heads off.
Old Jan 2, 2007 | 10:35 PM
3.4camaro's Avatar
your first thing sounds like the clutch slipping. be nice to the clutch. just dont floor it at 50 mph in 6th gear anymore
Old Jan 3, 2007 | 12:15 AM
CNTLSE 1's Avatar
Check the knock sensors also
Old Jan 3, 2007 | 06:56 AM
Toasty's Avatar
Doesn't the clutch slip smoothly in most cases? This causes the car to jerk back and forth.
CNTLSE, the only codes I have are the O2 sensor codes (long tubes).
Old Jan 3, 2007 | 06:10 PM
Toasty's Avatar
To the top
Old Jan 3, 2007 | 06:48 PM
Gauge's Avatar
11Second Club
I don't believe a code is thrown when the knock sensors are triggered. It doesn't show a light, at the very least.
Old Jan 4, 2007 | 01:35 AM
Toasty's Avatar
How would I know if its knocking and pulling the timing?
Old Jan 4, 2007 | 04:00 PM
Toasty's Avatar
Found the problem. I overlooked the O2 SES codes, one of them was for Bank 1 Sensor 1, which DOES affect air/fuel. Put the car on the lift, and the O2 extensions were touching the header and grounding out the wire. Just had to take it out, take off the melted plastic, re-wrap and tie it off out of the way. Problem solved
