Any Rocker Studs Avail?
Old Feb 18, 2002 | 08:51 PM
SNW Vette's Avatar
Default Any Rocker Studs Avail?
Hi,
I am porting a set of LS6 heads and I want to grind into the rocker stud boss that protrudes into the roof of the port. Does anybody make a rocker stud you can use with the stock rockers? I would like to glue in a set of studs so I don't have to worry about the stock bolt pulling loose after I grind the boss.
Thanks for your help,
Steve <img src="graemlins/burnout.gif" border="0" alt="[Burnout]" />
Old Feb 18, 2002 | 09:28 PM
steve's Avatar
Default Re: Any Rocker Studs Avail?
not sure...i believe its going to be 8mm.
call nick at are or craig gallant and ask them they might be able to get you in the direction you need to go.
steve frank
