HELP!!! have 2 rounded off rocker bolts
Old Jan 4, 2007 | 03:50 PM
  #41
matts22's Avatar
If he is using the bolt-out and it is not physically turning on the bolt, his problem is leverage, not a rounded bolt.
Old Jan 4, 2007 | 04:03 PM
  #42
jimmy 2 Times's Avatar
i did the same thing to the same rocker..........
what i did was heat it up with a torch, then hit it with a hammer. From there i got a set of vice grips and he-maned it off.
the vice grips will mess the bolt up, it is a cheap botl, and you are going to need to replace it now anyway
Old Jan 5, 2007 | 07:54 AM
  #43
eallanboggs's Avatar
If this bolt is under the cowl where a socket wouldn't fit a flare nut wrench (which is 6pt.) would be best.
Old Jan 5, 2007 | 06:55 PM
  #44
z28adiction's Avatar
Id try to go with those craftsman extractors. I use them all the time at work to get of rusty *** rounded off nuts and bolts.
