LS6 head --> combustion chamber size?
Thanks!
This is what I understand:
4.8/5.3 60cc
LS6 64 cc
LS1 67.5 cc
6.0 70-71 cc
Now I'm wondering how much volume is decreased by milling each of these .010,.020,.030,.040 etc. The 6.0 heads are looking prety good right now. <img src="gr_images/icons/wink.gif" border="0">
What size are the chambers on your 5.3l heads after porting and milling?
How much can be safley taken off before we run into intake manifold issues or decreasing the deck surface? I have heard of people going as much as 70 thousandths. <img src="gr_eek2.gif" border="0">
I haven't measured the chambers yet, I'm waiting for the valvejob. I'm going to measure the 5.3 heads soon and my stock 6.0's. I'll post when I do.
What would you do, 5.3 or 6.0 heads?
<strong>What would you do, 5.3 or 6.0 heads?</strong><hr></blockquote>
I was using the 5.3l heads on my solid roller motor and loved them. I had originally purchased a set of 6.0l heads to use, but I decided against it at the time. If you can get the compression up with the 6.0l heads, I think there will be a nice set to go with.
I'm debating on which set I'll use when I do heads. I would love to try a set of LS6 heads if I can find some used and cheap.
