Blown Head Gasket?
Old Jan 4, 2007 | 04:41 PM
transam69230's Avatar
Default Blown Head Gasket?
How would i know if i had a blwon head gasket. THe motor only has 38000 miles on the car. Its ideling really weird right now, and i asked a guy that knows quite a bit about cars and he said it was a blown head gasket, or a the cam is going flat, he hasn't heard the car yet, i just want to narrrow it down, and hope its not any of those two. Any input would be great.
Old Jan 4, 2007 | 04:49 PM
2001NBMZ28's Avatar
Overheating, coolant in the oil?
Old Jan 4, 2007 | 04:51 PM
brad8266's Avatar
Coolant burning smell, loss of power, and milky looking engine oil are indicators of a bad gasket. Do a compression and leakdown test to see if the values are low, if so you have a problem somewhere. The milky oil is a dead giveaway of head gasket failure.
Old Jan 4, 2007 | 04:56 PM
So change the oil, and see if it is milky. I put fresh oil in the car when i put it away for storage
Old Jan 4, 2007 | 04:59 PM
00 Freak's Avatar
I had a leak spot in the ground. Found out that my temp meter is garbage. I've heard their known to do that? WTF.
Old Jan 4, 2007 | 05:01 PM
I just hope i dont have blown head gasket because then i won't be able to get my converter installed because i will have to buy heads, and a cam to fix the problem. LOL.
Old Jan 4, 2007 | 05:58 PM
I Need Help
Old Jan 4, 2007 | 07:30 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Lets move this to the internal section for now.
