422 stroker
Old Jan 4, 2007 | 10:41 PM
FRANZ's Avatar
Default 422 stroker
Why don't you hear of more people building 422's. Is there clearance problems inside the block or something thats makes them less practicle to build than a
408?????
Old Jan 5, 2007 | 01:13 AM
SSilverSSurfer's Avatar
people are making bad *** power with less cubes
Old Jan 5, 2007 | 01:17 AM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
You don't hear much about them because of the long stroke. Many people are scared of the long stroke and reliability issues. Piston rocking in bores, pulling the piston too far down, and just burning oil in general. I think with the technology out now head wise they can make some major power and if built correctly should have none of the before mentioned problems. It's in fact the next engine I plan to build after I finish my current setup.
Old Jan 5, 2007 | 02:11 AM
PREDATOR-Z's Avatar
longer sleeves cure that
Old Jan 5, 2007 | 03:30 AM
OWN3D BY MY PROF!
Correct, although I plan to use an iron block personally.
