torn between cams
Old Jan 5, 2007 | 08:55 AM
midnightblue02's Avatar
Default torn between cams
cant decide on which cam and stall to put in my car... its 2002 A4 daily driver....ive been told to go with TR 224 114lsa, but then was told id regret it and go bigger... any inputs?
Old Jan 5, 2007 | 09:01 AM
JRracing's Avatar
man I'm in the same boat. But looking for bigger than that. I can tell you that I had a tr230/224 and it was awsome. I loved the low end power it made.
My car dyno'd 390RWHP with all the bolt ons and open cut out. Closed it made 385rwhp.
Is this a DD?
Old Jan 5, 2007 | 10:10 AM
drivinhard's Avatar
I've got a 224/224 114 LSA in my LS6 (Z06). With headers/vararam and tune it makes 393 RWHP. It's pretty mild, but works well. Good low end/drivability/idle.
Old Jan 5, 2007 | 10:47 AM
BlackScreaminMachine's Avatar
Internet Mechanic
I would get the 224/224 @ 112 grind, will make more low end power comprared to the same cam at a 114 duration.
Old Jan 5, 2007 | 01:35 PM
Bink's Avatar
224/224 - I'd probably go bigger.
Old Jan 5, 2007 | 02:03 PM
98Grnz28's Avatar
I have a Tsp 231/237. I drive mine everyday. I love it. Nasty lope and pulls really good from 3500+up. It all matters with the tune.
Old Jan 5, 2007 | 02:11 PM
98Z28MASS's Avatar
FM13/TR228/G5X2/Torquer v2 are th eones id look at. Do you have a stall yet?
Old Jan 5, 2007 | 02:40 PM
Blk97WS6's Avatar
hey man i was in the same position as you about a month ago. I was ready to order the Tr224/224 on a 114 lsa, before i ordered i decided to post up and get some other peoples opinions. Of coarse i got talked and persuaded into going a little bit bigger with the Tr230/224 on a 111 lsa. I could not be any happier with this cam. Its a great DD cam that makes awesome power, and my car isnt even tuned yet. its going in on the 17th, i cant wait to see what kinda power ill make!
Trust me, go a little bit bigger then what you think you want, you wont regret it!
Old Jan 5, 2007 | 03:41 PM
2000TransAmWS6's Avatar
i believe thats a common misconception,... the 114 should make more low end power because it has less valve overlap
Old Jan 5, 2007 | 03:52 PM
z28_n_tx's Avatar
are you guys talkin cam only?? or heads as well??? im also looking for a cam...i know the stall should also be done, but is it necessary??? i was thinking a vig 3000...if needed.
also does any one have any vids of the tr224/224 or the tr230/224 in idle??
will the rpms shoot up high wihteither cam??
Old Jan 5, 2007 | 04:37 PM
slow67's Avatar
Gingervitis Addict
Awe c'mon, I daily drive my TREX with a 6spd and 3.42s 20 miles each way.....in DFW traffic......
Old Jan 5, 2007 | 05:17 PM
Is this a DD?
yes its my daily driver, ive been asking around many forums and mostly everyone says yes, its a good cam but you will want bigger.... and i definently want to be happy with what i purchase so i will be considering another cam i guess
Old Jan 8, 2007 | 04:19 PM
slow67's Avatar
Gingervitis Addict
A 233/239 with a decent tune would be no problem as a DD
Old Jan 8, 2007 | 05:02 PM
caviness's Avatar
i have one i want to sell . 224/224 581/581 110+0 lsa, NIB
Old Jan 8, 2007 | 05:06 PM
bad2000z's Avatar
I like my X1
Old Jan 8, 2007 | 06:08 PM
SPRAYED 01's Avatar
Ill make a video tonight of my Tr224 on a 112. Its a great cam for a daily driver. Mines coming out for a more aggressive cam. Im trying to get a little more serious at the track.
Im installing a customer comp grind that my local speed shop and tuner recomended. Its a 238/242,.600/.610 on a 114+4. Should work well with my new auto setup and spray.
Old Jan 8, 2007 | 10:38 PM
SPRAYED 01's Avatar
Here is the sound clip of my TR224 on an advertised 112lsa. It actually was cam doctored and showed 111.5lsa. I opened the cutout mid video. Enjoy and hope this helps.
http://video.google.com/videoplay?do...85656349491294
Old Jan 8, 2007 | 10:43 PM
dirty2kTA's Avatar
when my car was a daily i had a y1 234/240 .598/.608 113 and i had no problems..
