timing problems
Old Feb 23, 2002 | 01:19 PM
DriveATransAm's Avatar
Default timing problems
i got my PCM tuned by MTI and just ran an a-tap run on the expressway today. my 02s are right at .89-.9. however, my timing is 23-24. i took the maft off when i got the tuning done.
before the tuning, and with the maft on i had the same 02s, but my timing was dead on at 28/29.
will the maft help bring my timing back up without messing with the 02s? im a little confused.
BTW: no TM is SWEET!
Old Feb 23, 2002 | 09:59 PM
Default Re: timing problems
<img src="images/icons/confused.gif" border="0">
Old Feb 24, 2002 | 10:15 PM
how can no one know?
Old Feb 25, 2002 | 02:11 AM
Raughammer's Avatar
D(irecto)r Pepper
So.... are you getting any knock? How many if any degrees of retard ya getting?
jc
Old Feb 25, 2002 | 08:18 AM
no nock at all. didnt see any at part throttle or WOT.
Old Feb 25, 2002 | 10:23 AM
Colonel's Avatar
Do some more Autotapping to confirm that you are never getting any KR. If still no KR but low timing I'd give MTI a call. It shouldn't be that low for NA use.
You might lean it out a bit with the MAFT but I don't think you'll get it back to 28 degrees without leaning it too far.
Old Feb 25, 2002 | 06:24 PM
Colonel's Avatar
Run a few more. I've seen low timing before from KR that was only happening about every 5th time I'd check it.
Old Feb 26, 2002 | 12:03 AM
i ran two logs, both had no kr <img src="gr_sad.gif" border="0">
Old Feb 26, 2002 | 10:33 AM
Matt98SS's Avatar
doesn't it keep the timing low for X amount of miles after the knock occurance?
