Building the enigne-What's reuseable??
LAter <img src="gr_grin.gif" border="0">
Oh boy r u really running a 346 <img src="gr_images/icons/wink.gif" border="0">
Good luck Bob
Hope to see u soon..
The Skipper
When I rebuilt mine ~2 years ago I reused the stock rod bolts and main cap bolts also. I don't think reusing these bolts contirbuted to the failure of my engine.
Just give anything you plan to use again a good cleaning (careful what you use, as some products could deform/deteriorate rubber) and visual inspection. If in doubt, replace it. Most of the gaskets/seals aren't overly expensive.
<strong>Oh boy r u really running a 346 <img src="gr_images/icons/wink.gif" border="0">
</strong><hr></blockquote>
I wish I had the money for an ALL Bore but I'm spending almost to much money as it is now. I'd probably be ok with just throwing this short block in there but I don't want to take ANY chances cause if anything happens before I log another 100 or so passes I'm gonna blow this damn car up
If you like you can come on down so I don't have to hear any BS once I do get back to the track, I know you're playing but if anyone around here wants to come down let me know <img src="gr_stretch.gif" border="0">
It Felt pretty good to actually need my torque wrench tonight as I'm finally finishing up the K-member and a-arms
So far the K-member, long wheel studs and lower a-arms are done along with cleaning up the steering knuckes(they look great once you knock all the rust off and squirt a little black paint on them). Hopefully the upper a-arms get here early this week so I can finish the front end and start building the beast <img src="gr_images/icons/wink.gif" border="0"> <img src="gr_grin.gif" border="0">
Mine were .016 and I ran the TR cam?Why would he only wanna mill yours .010?U can run more lift than u think but it has to do with the duration and timing events too.
Cartek has a set lift numbers they stick with for there S2X heads that I'm running but we r also using alittle more CR than 10.2
Good luck Bob.I would think a balance,rod bolts and new rings would be a fine setup.
JS
Good luck buddy
JS
