did i put enough oil on my filter?
Old Feb 24, 2002 | 05:43 PM
R U A LS1's Avatar
Default did i put enough oil on my filter?
I cleaned the filter the other day and left it out over night. I woke up and forgot about it, put some oil on realy quick and it only had about 10 minutes to dry and not the full 20. I checked it last night and it seemed dry (and i was being sure i put enough on so i squirted a lot on there) So i squirted more oil on there and only a little comes off on my hand after it had dried....unlike when it comes out of the box new. Did i put enough on anyways??
Old Feb 25, 2002 | 02:11 AM
AlonzoVersion 1.0's Avatar
Default Re: did i put enough oil on my filter?
[quote]Originally posted by R U A LS1:
<strong>I cleaned the filter the other day and left it out over night. I woke up and forgot about it, put some oil on realy quick and it only had about 10 minutes to dry and not the full 20. I checked it last night and it seemed dry (and i was being sure i put enough on so i squirted a lot on there) So i squirted more oil on there and only a little comes off on my hand after it had dried....unlike when it comes out of the box new. Did i put enough on anyways??</strong><hr></blockquote>
As long as its not drenched you will be fine.Just make sure your maf meter is clean and tb.
Old Feb 26, 2002 | 12:24 AM
35thSSman's Avatar
you're fine. you dont want too much oil on it. just make sure you have an even color all over the filter.
