My injector duty cycle is at 130%?!? Calculation help needed
What are your mods? You could have a fuel pressure problem. You might also see what leaning those O2s back to around .870mv would do.
20ms @ 6000 RPM is 100% 24ms is 100% @ 5000 RPM
Mike
[ February 26, 2002: Message edited by: Ramchargers ]</p>
<strong>The computer can output 200% duty cycle, of course the injectors will just be on all the time. You are seeing the commanded duty cycle by the PCM which ofen goes over 100% you need tuning or bigger injectors. Duty cycle goes up as RPM's increase since there is less time between pulses.
Mike
[ February 26, 2002: Message edited by: Ramchargers ]</strong><hr></blockquote>
So if it is over 100%, it must be injecting fuel on the compression stroke or something right? How can that be possible, unless I have some really high fuel pressure. So what injectors should I go with? Any recommendations?
