MAF Question???
Old Feb 25, 2002 | 04:28 PM
MOBE's Avatar
Default MAF Question???
I've been told that turning your MAF around will make your car run richer if its running lean. Can anybody validate that information? What are the pros/cons? Will it trip any codes? etc. etc.
Brian
Old Feb 25, 2002 | 04:33 PM
BIGBOS's Avatar
Default Re: MAF Question???
Its true, you should just get an MAFT to fix the problem and the MAFT will also help out a lot in the future
Old Feb 25, 2002 | 04:37 PM
MOBE's Avatar
I plan on getting an MAFT. But till then... this is OK?
Old Feb 25, 2002 | 04:38 PM
98ws6t/a's Avatar
how do u know if your car is running lean or what not???
Old Feb 25, 2002 | 05:04 PM
MOBE's Avatar
I'm getting engine detonation up around 5000-5500 RPM. I was told that it could be running lean, causing the detonation thus triggering the knock retard. I'm just trying to rule things out one at a time.
Old Feb 26, 2002 | 12:00 AM
z28steve's Avatar
My car did the same thing at high RPM's but it wasn't running lean it was running EXTREMELY RICH
why??? Anybody??
Old Feb 26, 2002 | 01:13 PM
CAlley2001's Avatar
I was running a little rich and I counln't understand it either. I had just put in some HPPIII programming, not the power programming, but just things like shift firmness, and shift points. Then I started throwing SES codes, PO420 I think it was. Innefiancy catylst something. I heard this was a problem sometimes with the HPPIII. Anyway, I reset my PCM and had my computer relearn all my modes and that took care of the code. Never seen them since. ANd in doing so made my car run perfect. I was around .90 and now I'm at .86-.87. So if you have alot of mods and have never reset your PCM you might try it. It worked for me.
