need quick help on pulley
how do i keep the pulley from moving on install...it an ASP on an A4.
i stuck a ratchet in the stock one to get it off, but i cant do that with the ASP..
TIA
jerry
TIA
jerry
Pull the inspection plug on trans.And use
large screwdriver to hold flywheel.Not
the best but it works.Also can pull starter
and stick a pc. of 2x4 in flywheel.I know
you don't have flywheel holding tool
or you wouldn't ask how <img src="gr_stretch.gif" border="0">
L - V HAWK is rite on:::the inspection plug is about the size of a silver dollar with two little tabs on it also there is a plastic flap above the starter where you can insert a screw driver withuot haveing to pull the starter
thx alot LV hawk <img src="gr_grin.gif" border="0">
got it all done...... <img src="graemlins/fluffy.gif" border="0" alt="[Fluffy]" /> <img src="graemlins/fluffy.gif" border="0" alt="[Fluffy]" />
