damn fuel pump
Old Feb 25, 2002 | 06:25 PM
mach1's Avatar
Default damn fuel pump
my stock fuel pump went out about a week ago and i installed a 255lph walbro, its been working fine and today it just decides to not prime up, after trying about 20 times it finally decides to, if runs fine but it doesnt want to prime after you kill the car. Any Ideas?
Old Feb 25, 2002 | 07:21 PM
mach1's Avatar
Default Re: damn fuel pump
no clues?
Old Feb 25, 2002 | 07:33 PM
cantdrv65's Avatar
I have heard the rubber hose that comes with the pump is shiiiizzzznt. It cracks very quickly.
Old Feb 25, 2002 | 07:53 PM
mach1's Avatar
Im using the hose that was on the old pump so :-/
Old Feb 25, 2002 | 09:05 PM
Colonel's Avatar
It's likely going to be something with the pickup tube. Better drop the tank and check it.
Old Feb 26, 2002 | 11:26 AM
mach1's Avatar
If it was the pickup tube wouldnt it go in and out? This will run fine as long as you dont kill the engine and if you do it doesnt want to come back again untill you turn the ignition 30 times, sometimes banging on the trunk above the tank will help, or it could just be good timing...
Old Feb 26, 2002 | 01:24 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Hitting it made it work?
Maybe a loose power wire?
Old Feb 26, 2002 | 01:38 PM
y2khawk's Avatar
First
Verify the pump is coming on w/ the key for the prime pulse. Listen to the tank while someone turns the key.
No noise, and it's a loose wire.
A loose hose between the pump and the hanger will cause a loss of prime pressure. Even it you used the old hose. It can happen.
I had a piece of rubber hose go on mine. Long cranks and loss of pressure at WOT.
Old Feb 27, 2002 | 12:54 AM
mach1's Avatar
now im hittin the hell out of the trunk above the tank and it wont do anything, <img src="gr_sad.gif" border="0"> damn this fuel pump is driving me insane...
Old Feb 27, 2002 | 02:56 PM
mach1's Avatar
k thanks for all the info, guess i gotta tear it back apart :-/
