Advice on my new Head and Cam package???
Old Feb 26, 2002 | 10:06 AM
2K1SO1LESS's Avatar
Default Advice on my new Head and Cam package???
Well i ordered my heads and cam package and a bunch of other stuff. They will be going in on March 7th. I was wondering if this is a good setup for a future ATI Procharger. Also what types of HP numbers am i looking at to the wheels. I will list all my mods.
Current Mods!!!
LT SLP Headers
SlP Y-Pip with Random Tech Cats
Borla Cat back
Air Temp Mod
MTI Lid
K&N filter
3:42 Auburn Gear
M6 lou's short stick
All BMR suspension mods
1LE Double Adjustables shocks
Mods being install on March 7th!!!
COMP LS1 224/228 .563/. 563 112 LSA CUSTOM GRIND
FULLY PORTED STAGE 2 HEADS W/MILLING 2.02/1.57 Valves
COM CHROMOLY PUSHRODS 7.350
ERADSIPEED ROTOR SET
DYNOTUNE PCM
PORTED THROTTLEBODY 00+
SLP 85MM MAF METER
SLP BELLOWS
INLINE PUMP KIT W/INSTALL
AUTOMETER DUAL POD
AUTOMETER AIR/FUEL
AUTOMETER BOOST GAUGE
HYPERTECH 160 POWERSTAT
ASP UNDERDRIE CRANK PULLEY Thanks in advance
Old Feb 26, 2002 | 10:19 AM
99MONGOOSE's Avatar
Default Re: Advice on my new Head and Cam package???
I would strongly look into upgrading the CRAP 10 bolt to a 12 bolt or 9 inch. IMOP you are wasting money on the Auburn gear set. Look into a Cartek or Ram clutch also.
Old Feb 26, 2002 | 10:21 AM
2K1SO1LESS's Avatar
Well the auburn is my stock unit.
I plan on upgrading to a Moser 12 bolt.
But not until my rearend goes out.
The car only has 3k miles on it.
Yes i know i will need a clutch, but my z06 should hold up for now. Once it goes i will get a new one.
Old Feb 26, 2002 | 11:16 AM
2K1SO1LESS's Avatar
looking for some advice!!!
Thanks
Old Feb 26, 2002 | 11:28 AM
BIGBOS's Avatar
I would suggest not milling the heads, you really don't want to run a higher compression with a procharger....what heads are you going with?
You should make some good rear wheel HP, defiently over 400rwhp
And that Z06 clutch will not last through one launch with that setup....mine went in 4000 miles...
[ February 26, 2002: Message edited by: BIGBOS ]</p>
Old Feb 26, 2002 | 11:39 AM
2K1SO1LESS's Avatar
[quote]Originally posted by BIGBOS:
<strong>I would suggest not milling the heads, you really don't want to run a higher compression with a procharger....what heads are you going with?
[ February 26, 2002: Message edited by: BIGBOS ]</strong><hr></blockquote>
Hey brian long time no talk.
Im going with the GTP Heads. This is what izzo recommends i go with.
Old Feb 26, 2002 | 11:45 AM
BIGBOS's Avatar
Glad to see ya over on this board, the GTP's are good heads..... <img src="gr_stretch.gif" border="0"> I saw my first ATI car saturday night, has a nice badass whine to it.... <img src="gr_stretch.gif" border="0">
Are you for sure getting the ATI??
Old Feb 26, 2002 | 11:47 AM
2K1SO1LESS's Avatar
<strong>Glad to see ya over on this board, the GTP's are good heads..... <img src="gr_stretch.gif" border="0"> I saw my first ATI car saturday night, has a nice badass whine to it.... <img src="gr_stretch.gif" border="0">
Are you for sure getting the ATI??</strong><hr></blockquote>
Yes i think so. The one with 8 psi or 9 psi. I forget the actual numbers.
Old Feb 26, 2002 | 11:50 AM
BIGBOS's Avatar
Yea, I want to get one sooner or later, go with the D-1sc supercharger instead of the standard P-1sc, you have a choice between 2 pullies too the 5lbs and the 7lbs....you will be around 550 rwhp with that on top of heads and cam..... <img src="graemlins/gr_hail.gif" border="0" alt="[hail]" />
Old Feb 26, 2002 | 11:54 AM
2K1SO1LESS's Avatar
<strong>Yea, I want to get one sooner or later, go with the D-1sc supercharger instead of the standard P-1sc, you have a choice between 2 pullies too the 5lbs and the 7lbs....you will be around 550 rwhp with that on top of heads and cam..... <img src="graemlins/gr_hail.gif" border="0" alt="[hail]" /> </strong><hr></blockquote>
Yea, well i will have to see what im going to do. Not sure yet, but ill be seeing you around the streets <img src="gr_eek2.gif" border="0">
Old Feb 26, 2002 | 03:00 PM
2K1SO1LESS's Avatar
TTT
Old Feb 26, 2002 | 03:15 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Definitely don't want to increase compression if you are going to install a supercharger.
Matter of fact it would makes sense to drop compression.
I have a 11.25:1 motor and I would need to run race gas all the time if I wanted to beat on the car, OR run so little timing the car might end up losing a lot of power.
Old Feb 26, 2002 | 03:17 PM
2K1SO1LESS's Avatar
[quote]Originally posted by Pro Stock John:
<strong>Definitely don't want to increase compression if you are going to install a supercharger.
I have a 11.25:1 motor and I would need to run race gas all the time if I wanted to beat on the car, OR run so little timing the car might end up losing a lot of power.</strong><hr></blockquote>
So your saying milling my heads will increase my compression?
I was told this is a perfect setup for a ATI procharger.
Old Feb 26, 2002 | 04:09 PM
Ragtop 99's Avatar
Do not mill the heads. This increases compressions which increase your risk of detonation and major bottom end damage. If you are definitely getting the S/C, contact ARE about a head gasket designed for boost.
Old Feb 26, 2002 | 05:12 PM
BIGBOS's Avatar
With the setup the bottom end will wear out faster than usual, but its still fairly new considering you only have 3000 miles on the car...
Milling the heads will bump you up to 11:1 compression....
The best setup would probably be to go with some forged dished pistons, and forged rods....that would make you compression a lot lower and throwing an ATI on top of it wouldn't really run any risks....
Old Feb 26, 2002 | 05:20 PM
LS1Tech Co-Founder
Milling the heads means you are in effect planing off some of the surface.
You will in effect make the combustion chambers smaller, this makes sense right?
This increases compression.
I know that heads sometimes need a .010 cleanup, and perhaps that's unavoidable, but in some cases BLOWER heads might be for example truck heads which have 70 cc combustion chambers vs the stock 65 or cc's that we have. In some cases some BLOWER heads feature combustion chambers that have been opened up a little bit.
Old Feb 26, 2002 | 05:21 PM
BLMONGOOSE's Avatar
I just purchased heads, Cam, and ATI supercharger combo. I talked to the guys at Gold West Performance and they sold me on this package. I had called everyone LPE, ARE, MTI, VHP. And in my opinion Gold West really new what they were talking about and they new exactly what
I wanted. MORE POWER and RELIABILITY...
They told me that the head and cam packages they sell are specifically tuned and ported for supercharging. And on top of that the PCU program they are going to send me is tuned for the heads, cam, and supercharger. I should be making close to 575-600rwp after all these toys are pieced together under the hood.
I cant wait <img src="gr_grin.gif" border="0">
If you talk to them ask for Kenny, tell him that Carlos referred you.
<img src="graemlins/corvette.gif" border="0" alt="[Corvette]" /> web page
Old Feb 26, 2002 | 05:24 PM
BLMONGOOSE's Avatar
Sorry I inserted the wrong link
<a href="http://www.goldenwestperformance.comGWP" target="_blank">www.goldenwestperformance.comGWP</a>
Old Feb 27, 2002 | 07:55 AM
2K1SO1LESS's Avatar
Alright guys thanks for the replys.
Old Feb 27, 2002 | 09:38 AM
2K1SO1LESS's Avatar
Otherwise this setup looks good minus the milling on the heads?
