Knock Sensor Removal
Old Feb 26, 2002 | 03:41 PM
FreakZ's Avatar
Default Knock Sensor Removal
Does anyone know how to get the knock sensors out of the valley cover?? I have my motor apart, but that is the only thing I can't seem to get out. Is there a special tool?
Old Feb 26, 2002 | 05:43 PM
Plan B's Avatar
Default Re: Knock Sensor Removal
I’ve done this. After you lift the rubber seals back, unclip the electrical plugs then with a socket they should undo!
Old Feb 27, 2002 | 09:29 AM
FreakZ's Avatar
How do they unclip? I can't seem to get past this point.
Old Sep 21, 2005 | 09:08 AM
tooljake's Avatar
Ditto
Old Sep 21, 2005 | 12:46 PM
ArcticZ28's Avatar
They are a sort of oblong-shaped connectors. If you take a pair of needle nose pliers and squeeze the oblong shape at each oblong edge so that it forms into a circle (understand that?) it will unclip the wiring from the sensors.
