tuning for larger injectors
Old Feb 26, 2002 | 08:23 PM
99 camss's Avatar
Default tuning for larger injectors
I've just added SVO 30#ers to my set up. I've got a MAFT and Autotap, and I'm looking for numbers/paramaters to shoot for N/A, as well as with the dry shot. Thanks for your help.
Old Feb 27, 2002 | 10:13 AM
Colonel's Avatar
Default Re: tuning for larger injectors
Get your part throttle Ltrims to around + or - 8% and your WOT O2s to around .870-.900mv for starters (or .900-.930 for N2O use.)
Adjust the base to set your Ltrims. Recheck after a couple hundred miles.
Final setting of the WOT should be done after the Ltrims have had plenty of time to settle down.
Do not use the base setting to adjust WOT O2s. That's what the WOT setting is for.
[ February 27, 2002: Message edited by: Colonel ]</p>
