One more time!
Old Feb 28, 2002 | 06:13 PM
MOBE's Avatar
Default One more time!
I know I've asked this before <img src="graemlins/gr_zzz.gif" border="0" alt="[boring]" /> ... But, what kind of ground clearance can I expect from the Hooker LTs if my car has been dropped???
I am going to get them soon if I can get a clear answer on my clearance issues. <img src="images/icons/confused.gif" border="0">
So!... Those of you that have Hooker LTs on a lowered f-body or anyone that knows for a FACT, that this application will work, PLEASE!!! let me know. <img src="graemlins/gr_hail.gif" border="0" alt="[hail]" />
Thanx
Brian
Good times everyone <img src="graemlins/gr_cheers.gif" border="0" alt="[cheers]" /> !!!
Old Feb 28, 2002 | 06:25 PM
CySevans's Avatar
Default Re: One more time!
My car has been dropped (Eibach pro kit) and I have the Hooker LT's. There were zero clearance problems with the headers, but the Y-pipe hung lower because it wasn't flattened and I used 3" tubing. I also had the shop use clamps to secure the Y-pipe to the headers, which made it even lower. I have about 3-4" of total underside ground clearance now if that helps you, and that's with the car sitting, not bouncing. I was able to bottom the car out even before installing the headers if I went too fast over speed bumps (suspension travel). It's pretty low, and I scrape the Y-pipe even on low speed bumps. But the headers fit perfectly and are tucked up underneath quite nicely.
