another stupid flycutting question...
I am going to be flycutting to clearence my soon to be setup... here are the head #'s, for ref. they are patriot LS6 stage 2.
2.02" Intake
1.57" Exhaust
I would guess 2-1/4" cutter?
How do I determine the correct cutter size? I will most likely be using my stock 853 casting heads so what size guide do I need? 8mm?
Thanks for the info!
2.02" Intake
1.57" Exhaust
2.02" Intake
1.57" Exhaust
2.02" Intake
1.57" Exhaust
If you dig under my name, I have been through this whole thing.
You need a 2 1/8" cutter for int. The pilot shaft should be the dia of a push rod. 5/16" I think. Make SURE the pilot tool is not loose in the hole. It will bounce around causing the tool to chip teeth off of it.
My ext cutter is 1 3/4".
what H/C are you running? Do you have a donor head I could use. I will be running ported LS6's. Can I use the same diameter cutter for both cuts using the larger on both?
Your PM's are full
Your PM's are full
PNT-218 .. 2 1/8'' Intake valve cutter
PNT-134 .. 1 3/4'' Exhuast valve cutter
NP - 516 .. 5/16'' PILOT
http://www.iskycams.com/pdfcatalog/2004-05/page17.pdf
how do you know when to stop cutting? im going to assume you have to have some sort of measurement so you dont mess with the compression and as to not damage the piston? then what about all the debris dropped into the cylinder.
Your PM's are full
Your PM's are full
I took duct tape and covered the top of the piston. This covers the ring gaps.
...Remember to go twice as deep as you actually need. If you need .030, dont just cut .030. P to V isnt closest right at TDC, the pistons is slightly downbore. Since the valves are on an angle, theyll move over a bit laterally. Thats why you need to cut deeper than you normally would, and then check afterwards.
very awesome thread. I have my set of original 99 ls1 factory heads that I guess I will sacrifice to my fly cutting cause...
They however have stock size valves, and the heads I now have (Patriot "LS6 style" heads) with welded up 59cc chambers on the car have 2.055 intake valves so the cutter I went with for that is 2 1/8" which I assume will not obviously seat itself properly in the factory head.
Is this going to be an issue?
Also, the exhaust cutter I went with is 1 7/8" and the exhaust valve is of course just shy of 1.6
(just FYI it is a custom grind cam, and the lift is well above .600")
Any and all help is appreciated, thanks!
bring piston to top dead center. tape off deck surface, and either use gasket, or layers of tape to simulate your new head gasket thickness and include if your milling the heads. in my case, I millled the heads .033 and used a .040 head gasket. so the stock head I used as the tool simulated .033 of that diff (unmilled right?!!!) and made the tape thickness added up to the rest of the .040" cometic gasket I used in the end. so the tape thickness owas .007". after tapeing, cut tape away to reveal the area to be cut. you want the cutter to rest on the piston, not the tape so you get an accurate cut. now bolt on the tool (old head with cutter in it) and let the cutter sit right on the piston. install the feeler gauge under the collar and on top of the valve guide and tighten down the lock collar. I then measured the distance to the tip of the cutter (valve tip sorta) for a referance # that I could double check when I was done cutting, to ensure the collar didnt move on me, creating a deeper cut then I wanted. after cutting insert a vacuum into the ports to suck up most of the shavings before you pull the head off. then immediatly vac. off the rest to keep that **** from getting anywhere else. then sand off the sharp edge around the cut and wipe clean with a paper towel and some cleaner.
another tip is to spray the cutter teeth with wd40 before bolting on the head. the cutter will operate smoother, and you'll get a nice smooth cut. heres more pics.
measuring the depth of the cut to keep consistent cuts in all the cyl.s. you'll find some of the valve guides will be a few thousandths off. an easy way to see if there all the same is the width of the cut at the bottom. the deeper the cut is, the wider it is. some of mine werent as wide as the others after the first go around.
hope this helps you fella's.
Originally Posted by TheLS1Kid
May be a stupid question, but does flycutting lower your compression ratio?
