Need assistance on forced induction camshaft
Old Mar 1, 2002 | 09:37 AM
C5AJ's Avatar
Default Need assistance on forced induction camshaft
Hi,
In the near future I am going to get a forced induction setup for my car. In the meantime while money is tight, I would like to get started at some point so I thought a cam would be a good choice. Since I have decided to go this route (forced induction) what kind of cam parameters should I be looking for.
So far it is my understanding that wide lobe centers(little valve overlap) is desired. Is this correct? What about lift? Duration?
What about split lift, duration>? or just a standard design.
Old Mar 1, 2002 | 11:38 AM
C5AJ's Avatar
Default Re: Need assistance on forced induction camshaft
come on guys.... <img src="graemlins/burnout.gif" border="0" alt="[Burnout]" />
Old Mar 1, 2002 | 02:04 PM
Kilroy's 99 TA's Avatar
I got a 219/224 cam with a 114LSA for my powerdyne on an A4, I think the conventional wisdom is get a higher exhaust duration than intake for forced induction....
219/224/114 was as "wild" as I wanted to get, but then again I'm a pretty mild kinda guy....
Old Mar 1, 2002 | 03:56 PM
Z00's Avatar
Z00
The 218/224 comp cams is a good one. I also have it for sell in the classifieds section if you are interested in it.
Old Mar 2, 2002 | 12:14 AM
y2khawk's Avatar
How much power are you looking for??
I've done quite well w/ the stock cam and heads <img src="gr_stretch.gif" border="0">
Old Mar 2, 2002 | 12:51 AM
C5AJ's Avatar
LOTS!!!!!!!
I just figured that in the interem this would be a good mod to do and it isn't as expensive for the time being and that when I get the system I want it would help. I know when you are going to forced induction that usually the stock components are adequate.
However...I want something to do now.
Old Mar 2, 2002 | 10:17 AM
C5AJ's Avatar
Z00:
Which classifieds section?
What is the lift?
Old Mar 2, 2002 | 03:54 PM
Cool28's Avatar
Tire Smoking Tranny Blowing Director
I got a b1 cam. All be it not as good as a turbo cam but cant be worse then a stock cam <img src="gr_stretch.gif" border="0">
