Anyone here spun a main bearing?
Old Mar 1, 2002 | 11:49 AM
phenyxTA's Avatar
Default Anyone here spun a main bearing?
I'm just curious what your car was doing to make you think something was wrong. Like did it make a certain noise or did you get a lot of vibration in the drivetrain? Twice now when I've floored it from a 10-20mph roll and ran it up to about 70 when I let off I can hear a squealing sound coming from the engine bay. Also the shifter starts vibrating really bad. It only does it for about 10-20 seconds and then goes back to normal. What's weird is it only does it if I spin the hell out of the tires. There's also a mild ticking sound coming from the motor under normal driving. Any ideas what the problem could be?
Old Mar 1, 2002 | 01:35 PM
phenyxTA's Avatar
Default Re: Anyone here spun a main bearing?
Thanks, I feel MUCH better now. I forgot to mention that the oil pressure was fine too. Looks like I gotta keep diggin.
Old Mar 1, 2002 | 02:19 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Been there.
Oil pressure fluctuated wildly at idle.
Pronounced vibration at 2500 rpms and higher.
Major loss in power too.
Obvious knocking, not as deepsounding as a SBC, coming from the middle of the engine.
Major shavings in oil... Huge gray streaks...
Old Mar 2, 2002 | 12:18 AM
Reckless's Avatar
Super Moderator
Been there. Doesn't "sound" like a main to me. If you torch or wrap a main, you will see a marked decrease in oil pressure and sometimes get a deep knock inside the motor. Sounds like a loose belt or bad belt tensioner could be the squealing (sudden change in rpm causing belt to slip). Not too sure about the vibration though.
