Anyone who has relocated oil filter- Advice???
I'm about to relocate the oil filter and install an AccuSump. Would appreciate advice about braided flex oil lines.
Summit lists Earl's Auto-Flex hose with no PSI rating as well as Aeroquip hose with 1000 PSI rating which is less expensive. Pegasus lists a braided oil line (no-name) that is even cheaper.
I'm looking for the best quality braided oil line hose and AN fittings regardless of cost. Thanks for any advice.
Post some pics and instructions for that; I'd love to have a remote-oil filter (Away from exhaust heat!)
Are you gonna go with dual filters, or just one?
Thanks for the TTT, Colonel. I just talked with Canton (the AccuSump mfg) and they say that either Earls or Aeroquip will do in size AN-10 or AN-12. Guess I'll use Earls hose and fittings.
[quote]Originally posted by 1CAMWNDR:
<strong>Post some pics and instructions for that; I'd love to have a remote-oil filter (Away from exhaust heat!)
Are you gonna go with dual filters, or just one?</strong><hr></blockquote>
The filter and AccuSump will go where the battery was. I have the filter and adapter, AccuSump on the way. The filter is a single from Canton Racing Products http://www.cmfilters.com - http://www.accusump.com The filter housing is machined aluminum 6" tall. The filter element goes in at the top with four allen head bolts for easy replacement and flows 15GPM with 8 micron filtration and no loss of pressure. They also have a coarse filter element and you could most likely run the two in tandem. The adapter is machined aluminum and has 1/2"NPT openings for in and out.
Super Moderator
I just used the generic relocation kit from Permacool. It comes with hoses and everything for about $50. Works great. Relocated mine to the front. Mounted to the side of the frame under where the A/C cannister is. You can see the top of it near the bottom of this picture:
![](http://www.turbo-ws6.com/bay6.jpg)
