Starter bolt question
Old Mar 4, 2002 | 03:00 PM
JNorris's Avatar
Moderator
Default Starter bolt question
Is there a replacement starter bolt that has a 13 or 14mm head instead of the 15mm head?
Thanks
John
Old Mar 4, 2002 | 03:40 PM
FastOrange99Z's Avatar
Default Re: Starter bolt question
Im almost positive my starter bolt has a head that is 13mm. You saying yours is 15mm?
Old Mar 4, 2002 | 04:48 PM
JNorris's Avatar
Moderator
Yes, my starter bolts have a 15mm head. Are you sure that your's are 13mm?
John
Old Mar 4, 2002 | 05:54 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
They are both 15mm stock.
Old Mar 4, 2002 | 07:17 PM
Well, I just went under my car and checked. The head of my started bolts are definitly 13mm.
Old Mar 4, 2002 | 07:41 PM
JNorris's Avatar
Moderator
The reason I ask is that it is very hard to get a 15mm socket on the head of the long starter bolt. The black plastic access plate to the torque converter and the bolt head are too close together. A 13mm bolt head would make things a lot easer. I will check with the local dealer and see if I can get a 13 or 14mm bolt.
Thanks
John
Old Mar 4, 2002 | 07:56 PM
Camaroholic's Avatar
Hey John,
That black plastic piece costs about $3 at the Chevy dealership. So if push comes to shove, they can order you a new one. They did for me. <img src="gr_images/icons/wink.gif" border="0">
I found that if I'd have backed the tranny off about 1/16" without removing the starter, I would have been able to get a socket on that bolt and then pull it. But me, I used primal instinct on removal of that bolt. Bust the plastic plate, put the socket on. <img src="graemlins/gr_judge.gif" border="0" alt="[judgement]" /> <img src="gr_grin.gif" border="0">
-Andrew
Old Mar 4, 2002 | 08:38 PM
JNorris's Avatar
Moderator
Andrew,
That sounds like me. I ended up tapping the socket on with a hammer. Loosing up the transmission bolt sounds like a good idea. I will try that when I re-install the starter.
Thanks
John
Old Mar 5, 2002 | 01:02 AM
Jason99T/A's Avatar
I can shift faster than you.
FYI --> The '98 model year cars had starter bolts with 15mm heads. The '99+ cars had starter bolts with 13mm heads.
[ March 05, 2002: Message edited by: Jason99T/A ]</p>
Old Mar 5, 2002 | 07:46 AM
JNorris's Avatar
Moderator
Thanks Jason. I was hoping that was the case.
John
