input
Old Jan 10, 2007 | 11:09 PM
911ss's Avatar
Default input
whats your input on these cam numbers? its for my 99 ss m6
232/234 113lsa .595/.598 4 degree of advance.
Old Jan 11, 2007 | 06:29 PM
GuitsBoy's Avatar
Good cam. Thats what I run, only on a 112 LSA with 2 degrees advance.
Old Jan 12, 2007 | 01:54 AM
PREDATOR-Z's Avatar
I use the same but with 0 advance (it likes da juice )
Old Jan 12, 2007 | 02:05 AM
911ss's Avatar
awsome, i cant wait to put it in. what timing chain and oil pump did ya'll go with and where you get it from
Old Jan 12, 2007 | 02:11 AM
PREDATOR-Z's Avatar
I run LS2 setup (with gears) and ported LS6 pump
Old Jan 12, 2007 | 02:23 AM
911ss's Avatar
so after gasket kit, chain, oil pump, im doing a fuel pump, rods, and springs im pretty much set?
Old Jan 12, 2007 | 02:44 AM
PREDATOR-Z's Avatar
I would do injectors, if you are spraying wet then SVO 30s and if dry 42 lbs
