Deleted my PCV and Evap last night
ill post up a pic here in a second. used the autozone breathers. snapped a breather right on the PCV outlet in the front of my motor (fits perfect) and then put another breather on the drivers side valve cover where the hose comes off it. The fuel rail covers coverd it perfectly looks pretty sweet and even better, no more oil sucked into my intake when i spin the monster to 7100 hehe
huh?? lol the intake manifold is capped... that filter is going to the LS6 PCV
i think that everyone with a 408 should say **** it and cap the **** off.. i have had so many problems with sucking oil.. i think the shear volume of air it takes to fill the bigger cylinders, especially at 7k RPM's its impossible to run even a catch can. cap it off and change your oil more often, no more worrying about detonating from oil.
nitrous? what nitrous
not yet, i really dont think it will just because the only reason oil is really pulled into the intake is because of the large amounts of vacuum created by the motor. with the breathers as long as i dont have horrible blow by the engine should be creating its own little atmosphere and venting out some (not all) gasses out of the breathers as any pressure is built.
at least thats the way it "should" work lol. with my luck the breather will be made of dynamite and spontaneously explode and light my car on fire.. my luck sucks *** lol
no more oil smell after i do a WOT run i noticed already, VERY pleased with this mod.
Did you pick up any power by deleting the PCV system altogether?
car jsut flat out runs BETTER and CLEANER now. one of the best mods ive done!
It might be a good idea to run a catch cun in between your ps valve cover and throttle body. That way you still get some vacuum without the oil going into the intake.
Wes
