Running low 11s, high 10s without NOS
I'm wondering what kind of mods you guys are using to get an F-body LS1 into the low 11/high 10 second area without using NOS? N/A, supercharged, or turbo would be ok. How would you get an LS1 to run this fast, and what driveline components like rearend, trans, etc., would have to be upgraded? What about cost? Thanks.
Ben
'87 GN, TA49/w PT&E housing, THDP, Hooker exhaust, test pipe, Mease Performance Big Neck IC, 50 lb injectors, PT&E 100 octane chip, Cold Air Kit, WAL Fuel Pump, Stock D5, Nitto DRs, Direct Scan, bunch of other stuff, blah blah....
[ March 05, 2002: Message edited by: TRBON8R ]</p>
<strong> How would you get an LS1 to run this fast, and what driveline components like rearend, trans, etc., would have to be upgraded? Ben </strong><hr></blockquote>
Motor? stock bottom end 346. Heads GOOD stage 2's with a medium sized cam. Somewhere around a 222/222 would do it. (did it for me)
Tranny? A rebuilt Yank 4L60E with a Yank Pro Thruster 4400 converter.
Rear end? stock with 3.73 gears
Suspension? LCA/PH and an air bag.
Misc: headers, programming, bolt ons.
Thats it. There is a lot of info on how "I" did it on my web page. check it out. (see sig.)
Welcome to LS1tech, y'all come back now... ya hear? <img src="gr_grin.gif" border="0">
JS
Use to have a 3750lb 11.5 GN
Running high 10s on a blower/turbo setup is pretty easy. Stock weight, tranny rebuild, stall, better rear end, blower package, stock motor, etc. Probably set you back 12k in parts.
Running high 10s on motor takes some weight reduction, but can still come in around 10-12k.
Some have gone 10's with bigger motors.
Some have gotten then with superchargers and turbos.
I'd go with an automatic tranny.
I always like 'Gold Formula', Brian went 11.1 back in 2000 with a intercooled 9lb Vortech, and boltons.
Take a look in drag racing, and look at the lists we maintain.
My car has a big motor, and we're still dialing it in.
But I have gone 11.1 on pump gas at 3600 raceweight at 800 ft above sea level. Even shifting my 422ci at 6100 would probably yield me a 10.9 at HRP.
Terry Burger, sorry I've never run at Irwindale before. <img src="gr_stretch.gif" border="0">
Ben
[ March 06, 2002: Message edited by: TRBON8R ]</p>
It's GM! <img src="gr_grin.gif" border="0"> <img src="graemlins/gr_cheers.gif" border="0" alt="[cheers]" />
See my website for details <img src="gr_grin.gif" border="0">
Tony
