what is the biggest cam for stock ls1
TR224/224, cheaTR cam, or ask shops. Sounds like you need a custom cam dude. You can get the duration and lift you want and get closer to a 114 LSA (semi smooth idle), or you could just say screw it and go hardcore and look bad *** @ every light!!!
Originally Posted by thedreamer
i forget to tell u that the car is daily drive and i don't want it too rough idle
actually lobe seperation does not directly affect the lope of a cam......overlap affects the lope of a cam; however, lobe seperation does have a direct relationship with overlap......
To find overlap you simply add the duration of the intake and exhaust together, divide by four (4), subtract lobe seperation (LSA), and multiply by two (2).
Take for instance these 4 cams:
My first custom cam 224/224 .581/.581 108lsa has 8* of overlap decent lope
Thunder's 224 cam 224/224 .563/.563 112lsa has 0* of overlap little to no lope
Thunder's Trex cam 242/248 .608/.612 110lsa has 25* of overlap heavy lope
my current cam which is as big as I believe will fit in a stock head stock valved motor witout flycutting has 29* of overlap extreme lope
I daily drive my car and have no issues with anything.....I have a friend whos cam has 34* of overlap and has problems breaking due to low vaccum. I hope this helps in determining lope and drivability.....
what about cheater cam 214+230/4-117*2 = -12 is it smooth also
if the overlap 0 means its smooth
yeah after driving the trex for a while its not as bad as some people make it out to be and can definatly be daily driven (mine wasn't even tuned), its just not going to be as smooth as some of the other smaller cam choices.
#32
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
#35
LOL may be a smartazz remark but..... my answer is sell it get a 4 banger or get with the program and go big cam & big stall or big cam and spec clutch and learn to drive it hard and fast they way we all do lol ........ " just a joke " but a very good point
#36
![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
#37
Ha ha I had to laugh we start with "I want the biggest cam for the LS1" to " Not to big as i need it to idle great for dd" to a baby 224/224 cam!!!!!
Good thread!!
Dan
Good thread!!
Dan
#38
Good thread!!
Dan
Good thread!!
Dan
#39
Location: The Republic of Texas, just south of the United States...
I run my 242/248 .625 on a 113 LSA as a daily driver with no problems at all, didn't flycut the pistons until the heads were modded, have never had a problem with driveability, sounds like a ******* prostocker/nascar coming down the street. Idles very well, very nasty...kind of like **** sex with a racing gas lube.....
#40
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
